Yeah, I was looking at it recently. The one click on and press and hold for off really irks me.
Manker just released a bunch of new lights including a 16340 90° head light called the EO4. The fixed clip and charger built into the battery instead of the light is not to my satisfaction.
I need to add all these new lights to the list. :weary:
Yup, it is like the Manker lights as well (and Sofirn’s).
The more I use Olights or the Emisar D4 the more the click for ON/OFF makes sense to me (specially being used to more tailclickies).
About the small Manker, it is cute, it is powerfull, but it is also expensive and the are some things on the UI that are a drawback to me. So I’ll stick to what I have for now as headlamps !
Good luck adding these to the list
:nerd_face:
Actually, the Mankers seem to have 2 ways to turn them on.
A one click on and press and hold for off (always turns on moonlight)
As well as a press and hold for on/off (to the memorized level).
I don’t know if this is new or not. Press and hold for on/off is not my favorite, but it’s not too bad, either. At least it’s consistent.
The Manker’s not too expensive at $45. Not like the Olight H1R at $67 or H2R at $90. ![]()
Sofirn doesn’t make a headlamp, do they? I guess you mean their regular lights.
Hum, I don’t think it is new! I have the Manker E11 (which is not a new model) and it has that click for ON on Moonlight and Press&Hold for memorized mode! I guess the best UI from Manker is the MK41 (direct access to Turbo from On/off without having to press & hold.
Yup, if compared, the price of Manker is “Lower” but ain’t a budget light! And Manker doesn’t go on GBs or discounts for BLF members :disappointed:
I wouldn’t mind get a H1R too, nice little headlight ![]()
Amutorch AL1 is not a headlamp at all. It is huge, very heavy, and even has no headband. (Overall quality much worse than H03)
Well, it will probably fit most of the common headbands for flashlights, it is a angled light, and it can be used in a “shorty” version!
Besides that, I don’t know, I believe that there are out there heavier headlamps that this one!! Take a look at the Thrunite TH10 … (yes, old model, but still a headlamp! )
Shorty
now it 106mm long (protected 18650 donot fit) and weight 71g (head is very thick and massive). Even short version will be more heavy than h600 with 18650.
Shorty
Although it is a comparison, I am not sure if it is a fair comparison! And please note that I am not defending Amutorch, despite it is a brand that I like!
The Zebralight is of course much lightweight than this. But it is also much more lightweight than an Acebeam H20 (62g) or a Boruit (55g) headlamp without batteries!
And it is SO much more lightweight that that Thrunite TH10 headlamp w/o battery (85g)!
That doesn’t mean that this cannot be seen as an headlamp.
But with the Zebralight’s price I can buy 2 of these Amutorch! And 6 Boruits ![]()
Maybe being a heavier is not an advantage, and I do see your point, but this may still be considered as such in my modest opinion ![]()
Of course:)
When I ordered AL1 I think it is headlamp. But when it comes, I clearly realise that it is not. It can be seen in many details that manufacturer dont think it as headlamp) It may be hard to explain, but if you take it in your hands, you would understand.
But of course it can be used as headlamp, as many other handheld lights and even a bit more convenient )
Those are all lightweight compared to the Jaxmnve H6 twisty head. With no battery, it’s 150g! A tank.
The AL1 is 78g.
My Al1 is 70.4 (without clip of course)
H6 definitely is not a headlamp:)
H6
Includes headband.
Not all angle light are headlamps , and not all light that could be fixed on head are headlamps)))
jason,
because i am not too bright (obligatory light joke) and just to reiterate,
may i ask again
what headlamp you are using for trail running?
and what is the beam colour of the one you are using?
i would prefer a warm or at least neutral light so i can
make out ruts and variations and such where my feet go.
cool white makes that difficult for me and slows me down
even more than my usual old tubby guy pace.
and, of course, i’m cheap.
thanks for this list and your time.
jason,
may i ask again
even more than my usual old tubby guy pace.and, of course, i’m cheap.
I don’t use my headlights for that type of stuff at all. Sorry.
Mine are for close up work like working on cars, motorcycles, soldering, etc… and they all have wide 60° TIR lenses in them.
No doubt the Boruit D10 is my favorite, plus it’s cheap. If you can solder, you can easily swap the 20mm emitter for whatever color you want. It’s about 650 lumen stock so it’s got some good brightness. Maybe try some high CRI leds. A new emitter is maybe $6 to $7 so you can build it for about $20. Then use a battery you already have. If you don’t need lots of throw, you might try a 30° TIR lens to give a wider hot spot than a reflector.
L, T shaped 18650 headlamps not suits for running at all. It is too heavy.
You should take a look at models with build in battery or cr123/aa. Something like http://s.aliexpress.com/uaYvMFjy. but I can’t find the weight.
It says 70g with built on 1200mah battery.
Is it going to be bright enough or have the right color beam? IDK.
jason,
may i ask again
You can look at
https://stirnlampen.reviews
It is in German (use Google Translate)
He does reviews of headlamps for runners
which one of the 18650 usb rechargeable you would choose?sadly,noone is with mtg2 led…![]()
