Heat solution idea.
TEC's were all the rage in the super CPU overclocking days in the 90's. I made a system which had a TEC attached to the venerable Intel Celeron. The TEC was cooled by circulated water. It was a whole lot of effort to get a few more MHz, but the fun was in the accomplishment. I look back and laugh at the effort required to get another 10% speed from the CPU, which would easily overclock with just air cooling.
Fast forward to today, I want to modify a HD2010 to the hilt. I guess the more things change, the more they stay the same.
To make up a favorable case, suppose one wanted a compact thrower, not to exceed a certain diameter, with a very bright long range beam, but didn’t care how big the spot was. I’m not sure what sort of optics would do this best, though I suspect it would be an aspheric or Fresnel lens with a fairly long focal length. Another possibility is a retro-thrower with the led turned backwards and a long focal length reflector. For any optics, one would need a small but bright led, probably de-domed. Since the led would be small, total heat output and power consumption wouldn’t be the main problem. It would be keeping the emitter as cool as possible with the highest current possible. So one could use a thermoelectric diode or some other sort of refrigerator to cool the (copper or silver) star. There are fluid refrigerators without pumps and pumps are not so hard to use, so I am not sure the diode would be the best solution, but it seems to beat passive cooling in this case. I think a fluid refrigerator would work better, because it could distribute the heat farther, but that a Peltier diode would be easier to do.
What's the difference in light output between LED at 85*C and 0*C? The theory sounds great - a simple little square thing that makes stuff really cold - but go ahead and build one, you'll see. If you don't have enough cooling to keep the LED cool, what will you do when the heat load is increased by more than a factor of ten?
Check this out: IsoSkin Superconducting Heat Spreader
Lots of other cool stuff and useful info, including calculators that’ll be helpful in fabricating efficient heat sinks.
I don’t have figures, but the ones I used a long time ago were better than ten out to one in. You could feel one side get cold in the air. Water cooled and in vacuum, they got well below freezing. They were also too expensive for this type of use. I don’t know how things stand nowdays.
IsoSkin looks great, but from just skimming the site, the pictures are all computer graphics.
I gather they give you a design, but you have to manufacture it yourself:
I'd love to try a heat pipe, but the complication level is very high.
The IsoSkin is sorta a heatpipe. A modified version (round with 2 holes for wires) could be routed out of copper sheet, soldered shut and stacked between shims to form the fins.
