Thats the truth,acetone is quite agressive, even the Noctiogon`s red paint started to “melt”
Things i tested so far:
- gas: slow, great shift tint, you need to “bath” the emitter afterthat in order to remove the gas residue
- acetone: faster than gas but more dangerous, lesser tint shift
- heat( heats comes from the emitter itself,while working): fastest method, lowest tint shift, dangerous one, the dome dont fell off at 100% usualy
- heat( the heat comes from a heat gun or a hot air solder station) a fast method, but its main issue is that the metal pad under the sillicone isnt heated enough and usualy there are lotsa sillicone leftovers
- heat combined( the working blade is heated too)…relatively good results here
In the matter of fact when i use gas or acetone method i usualy bath the emitter and the pcb with a hot(50+deg) water - believe or not it doesnt affect its work, of course to clear the gas and water residues i bath again with 100% alcohol afterthat
