Convoys are great because of the great quality vs small price compared to most of what’s out there
- The C8 is a great compact thrower, with the XP-L HI you’ll love it. Depending on how much throw you want, an S2+ with a smooth reflector and XP-L HI will throw enough, but not as much as the C8 , of course.
- Among the many S models, the S2+ is the more popular, has the most color options and accessories, some have a rubber tailcap, some have a metal switch, and some have both. Other models differ mainly in external appearance and reflector depth (the S2+ and a bunch more have a shallower reflector, the S6 and some others have a deeper one, but not by much)
- On Simon’s aliexpress shop (official Convoy shop) you can ask in the observations for options that are not available as default, like and old S2+ with the new driver, or XP-L led, or a clear S2+ with rubber tailcap, choose smooth (better for far away) or orange peel (better for close range) reflector, and I imagine more
- I’d get the 7135*8 driver always (ask for the new firmware if you are not buying a model that already ships with it by default). With the new firmware you can set it so the second to last mode can be 20, 35 or 50, so you’ll always have your nice brightness without a lot of heat, and 100 will always be there for the wow
- I’d go with the second coolest led tint (usually 3A or 3C). A lot of people here like even warmer tints, but that is a matter of preference
So, to recap, choose your model/color, ask for the new firmware driver if it’s not already default, choose the led you want (ask Simon if it’s not on the list)
For batteries, if you are using convoy drivers (max 2.8 amp draw) panassonic NCR18650B are more than enough. the sanyo GA or samsung 35E will give you better current if you ever get a flashlight that draws more amps, but I’d only get the samsung 30Q if you really plan on having a higher drawing flashlight, as the lower capacity puts them at disadvantage for lower current flashlights
[quote=Lightbringer]
If you mean this:
than he has!
