Yep, that is the advantage of using a spectrometer to measure light levels. Chibi and me are using a luxmeter in our spheres, so we can not correct for spectrum changes. I had a few lights measured by maukka in his sphere two years ago, with varying tint and CRI, the diffence between his and my calibration varied by as much as 4% for the different lights and I assume that the difference comes from the fact that maukka compensates for spectrum changes and I can not.
Just curious as someone who has never done this before… is measuring CCT & CRI supposed to be done in a sphere, or are there other/better ways of doing it? I suppose a sphere would help integrate angular differences of certain LEDs (think Cree flip chips with bad tint shift). But is there another way that wouldn’t introduce variation, like the sphere does by absorbing certain wavelengths more than others?
I use my sphere for measuring light output, not for CCT/CRI because I know that it changes the CCT. So if I post CCT/CRI numbers, I always add how/where it is measured (usually the middle of a hotspot from a reflector or a TIR because that is how we mostly use leds).
Maukka can measure integrated CCT/CRI of a led in his sphere because he does the spectrum correction, but he usually also measures in the hotspot of an optic because that has more relevance.
Depends what you want to measure, if you want to know the tint of the spot then you just shine the flashlight dead on the sensor. If you would want to measure the whole angle profile then you measures at several angle and that tells you how much it varies (see maukka reviews or my thread about LH351D slicing), which is quite important, you might have a nice integrated tint but an absolutely terrible angle profile, as you mentionned somme CREE LEDs are terrible in this aspect, or a 144A might have a terrible egg yolk effect and a nice overall tint.
If you’re measuring a LED bulb, the diffuser averages pretty well already, usually there is very little variation.
Honestly I’m not sure when integrated color measurement is an important metric, I guess for comparing bare LEDs mostly.
Yes as I and Djozz mentioned, the sphere must be color calibrated, even professional ones.
Still saving for a Sekonic Spectomaster meter since last year. ![]()
Dayum that’s a lot of money. I’d probably rather make a firearm purchase for that money. I think a lever-action rifle in .357 magnum would be great fun. Although the price of ammo is greatly inflated right now.
