Which c78 are you comparing it to? The one I have has no unevenness in the whole zoom range, whereas the rc29 has squarish (cree) artifacts until all the way in flood.
agenthex: I was talking about full flood , which is my most used mode on flood-to-throw lights. I don't have any real usage for the throw or half-flood. The RC-29 are from KD and the C78 from DX. Maybe we have different models of those lights. I am thinking about buying those pseudo Zebralights from Ultrafire.
The part I was wondering about was this:
beam has less artefacts on flood
I don't see any artifacts on flood other than the typical "ring" around the edge of the flood that all these light have, and different c78 "batches" are known to be completely different.
And I wondered about your complaints about the optics of the RC-29. I should have said: The RC-29 has an even smoother beam than the C78 on full flood and the brightness is more evenly distributed from centre to the edge on the RC-29 (on full flood).
On the other hand I have given away all my RC-29 (had 3-4) and kept the C78 .... go figure. I like the C78 overall design better (blantant copy of the led lenser P5), but the RC-29 is the better light in my opinion. But the twisting action + the already mentioned sharp (tactical ) switch ruins it for me a bit. I would buy a C78 for myself and RC-29 as a gift/present for others. I personally like the ability that the C78 fits perfectly in this headband and makes it into a cheap high power headlamp.
To clarify again, when you start with square image at full zoom on the rc-29and start twisting to flood, artifacts of the cree square remain in the beam until you get to almost full flood. Now, it's probably not a big deal like cree reflector rings aren't a big deal in real world use, but it does indicate that the lens design is not as good. Still, I would agree the rc-29 is more versatile at full flood since it can illuminate over twice the area, it just takes a while to get there and sometimes you accidentally turn the light off. The slightly better build quality/polish also helps makes it a better gift.
Also, for my specific samples, the rc29 at 2.5A draw is same brightness as c78 at 2.0A, and a bit blue.
Sashix, if you read forolinternas you will see that the sipik http://www.dealextreme.com/details.dx/sku.39585~r.43033281 has a better construction, quality and same power as all C78´s. Also capable of both AA and 14500. Pity only 1 mode. I have ordered 1, still not arrived
Also in gray http://www.dealextreme.com/details.dx/sku.39584~r.43033281 but a little more expensive
Lets see .... Shekor charger has changed , for the worse apparently .. SO at this time I would say Xtar - 2 bay charger ...
If I know who made the Shekor charger I would contact them about stuffing up what was a good charger .
What do you mean? New versions have gotten worse or something happens to yours? And as far I remember, Xtar charges batts a bit higher than Shekor. I found Shekor @ KD for $10,28. But where I can buy Xtar? Only found it @ ebay for about $15. Is it a good price? Thanks, Matt ;)
PS: thx for the info, Fran ;)
They have changed the Shekor charger internally ... If you buy one now , it will be different to the one I tested ...
Apparently the new ones do not terminate on completion , and can over charge ..
Yes , Xtar is available on Ebay , just find the best price ... $15 is cheap , $10 is cheaper , but they changed the Shekor for the worse ...
Ahms, thx for the info. I think for $15, Xtar is better than UF WF-188, for example. Have you tried it?
The Xtar is the closest to what you might buy from a large local retailer instead of something that looks like it came from a backyard shop.
I own the WF-188 and the Xtar ... I like both .. The WF-188 offers more charging options ... [ If you need them ]
But if you just need a 2 channel charger , the Xtar is fine ...
Ok, so I bought it Now, what's the best place to buy TF 14500 flame? $5,34 @ DX, $5,33 @ LT... but prefer to pay a little bit more but get good ones.
That's like asking whether it's better to buy your Nike Airs at walmart or target. Out of the two, though, DX tends to at least on flashlights to ship out cheaper copies after the initial quality of an item makes it popular.
