Edit, never mind.
Good explanation Lexel
Ok. So with High drain battery the led is gonna die fast ?
In seconds, or in minutes ?
Maybe I test this… Lol .
What about those normal good batteries ? Still minutes and dead ?
Im thinking to buy the MF02 …
That looks good light to me
You need 4 x 18650 cells for the MF02, the xhp35 only does 2500 Lumen max.
I think you’d better get a Q8 for less. (Around 50usd, with discount)
Or a convoy L2 with XHP50
Damn… Have to look these also.
Im gonna go to local shop to get good 18650 batteries do explore the light…
Friend gave me samsung normal 18650 batteries…
Everything same. Working fine, same lumens.
Well a little brighter… After test shots…
Sofirn SP36 or Q8 are very good budget lights
really good quality and brightness
very useful allrounder in medium distances
MCPCB current depends a lot which material used to build, top is best lowest is bad
Copper DTP
Aluminum DTP
modern aluminum ultra thin aluminum-oxide layer
copper with thin ceramic glue insulation layer
aluminum with thin ceramic glue insulation layer
copper with polymer glue insulation layer
aluminum with polymer glue insulation layer
the bad news is the worst is cheapest to produce
Or THIS one ?
Thinking of one myself, really a good price for such a XHP50 light with the discount
any decent light will likely out throw your Berg
even with half the lumens a XPL Hi in a 4-5cm wide reflector thrown pretty good
Just got more open the light :
Is here something that needs mods for more light ?
looks like 2 tiny MOSFETS to pass the battery voltage to the head part, possibly PWMed
rest is charging board, which still is very doubtful looking on the batteries in series
with some basic samsung 2600mah batteries it gave me 2hours and 6min of working time.
40min on the china 4000mah vs
126min samsung 5200mah
So the batteries that came with this light have less than half the capacity that’s printed on the wrapper.
yes. And with Samsung batteries the light gets a bit more lumens as well.
And funny thing was that reload time for Samsung batteries was around 3 hours…
and the china model was 2 hours…
so china batteries were really bad ones…
Just ordered:
Astrolux c8
Astrolux s1
After those maybe some big boss light …
Both are great lights
I´m ordering batteries for those lights :
18350 for the s1 ( I want to keep that small light )
is that good enough ?
and 18650 for the c8 :
just ordered…
@jarkko, both are great cells.
You will not be dissapointed.
