Do you understand basic electricity concepts? Volts, Amps, Watts (Power), etc? You’ll never have a real grasp on this sort of thing if you do not, that’s just how it is. If you DO understand the very basics then you can pigyback LEDs on that (they are special). Take a look at my posts in these two short threads:
Most of my p-60 18650 type flashlights pull about an amp maybe 1.10 average ..up to 1.5.To me this seems normal . And my cheaper lights do pretty poorly as wellsomewhere between 1/3rd and 3/4ths of an amp..again to be expected .. So why do my AA tank 566 and 568 pull about 2.15...My small sun AA zy-c55 about 2.25...and the AA eastward YJ J09 a whopping 2.75. ( no wonder i like my Eastward ) is this common of AA lights? Is this because of the driver ? are they overdriven? None of my lights …
I see constant current, direct drive, 7135 drivers, etc and wonder what it means exactly and what I need. What do these things spit out? For instance, do constant current drivers always pull the same amps?
Also be sure to go back and at least skim lagman’s thread I referred you to earlier.
If you want “help” (guidance) and not “being told what to do” you’ll need to do two things:
- increase your understanding of what’s possible and how this works
- make some decisions as to what kind of light you want this to be
For example, your tentative choice of the LD2C… it can supply 3A to a single LED. Something like 9W of output power. That’s all it’s been tested to do. That’s like one regular EDC flashlight for most of us, nothing impressive at all. You said you wanted powerful, I assume the equivalent of an everyday carry flashlight is not what you were thinking of.
EDIT: And FWIW I don’t 100% agree with Fritz t. Cat. Your host probably won’t do well with continuous direct drive (DD) at high current. I’d say the best thing is to implement a DD driver with turbo stepdown if you wanted to get close to “true” DD performance but be able to operate the light for more than 60 seconds at a time without damage. Even a showoff light has to stay on for a couple of minutes sometimes.
