I was doing other stuff, so I did not pay close attention to that. I only worked on the bottom side. On the bottom side, it seemed to me that the FET and sense resistor both got hot. The sense resistor became hot faster I think.
[quote=HiTiT]
:~ strange, both of the FETsā are rated >8A on their datasheets.
I assume that it shouldānt get really hot on ~2.8A ;\/quote] I was working on measuring other stuff. Soon Iāll take a closer look at where the heat is really coming from.
Iād say that at 100% duty cycle this driver produces a good bit more than 2.8A out, although I have not measured. Probably around 3.5A+ output. The input at 8.2v (IIRC) was ~1.85A. Thatās 15.17W input, so make whatever efficiency assumptions you want (80-90%) and figure the output based on that.
I dug this up just to post I found out what the black SMD component was, itās when a SMD cap and resistor have a love child no seriously its a component called a ferrite bead.
Also my v06 boards are coming so I expect the 07ās to be a day two behind, as is usual with FT I donāt expect the driver till around middle to late August.
As far as I can tell an SMD ferrite bead would be a choke. I do not think that the component is a choke. If it was a choke I think resistance should be lower than 100k. Take a look at the DC resistance figures for some. They are ~100ohm or so and as I said in the OP this component is 100 k ohm.
My v07ās shipped yesterday!
A member here graciously sent me an extra LD-29. A good thing since mine is getting a little worse for the wear (from moving the PIC on and off, soldering wires to the pads, etc). Anyway it was ordered from FT on the 8th and arrived on the 17th with USPS - so 9 days from start to finish.
The new version LD29ās are somewhat different. Iām not yet sure what the implication of this is.
still uses the PIC 12F683 MCU
FET appears to be the same, an SO8 package 4435
the diode is now SBM1040.
an SO8 FET has been removed This missing part appears to be IRās IRF7821.
It seems to me that IRF7821 was replaced with the tiny 8205S, but I have not looked into this closely.
SBM1040 is a 5A continuous diode in the Powermite 3 package. This package seems to be about the same size as PowerDi 5 but may be superior? Iām not sure that Powermite3 is actually superior to PowerDi5, but itās definitely a modern high power diode so thatās good. The old diode was marked 3912 and I have no idea exactly what it was rated for. Maybe 3A, who knows. The new diode is certainly better!
The 4435 FET I assume to be a 30V P-Channel trench MOSFET. The new one is marked 4435AG and the old one was simply marked 4435.
Come to think of it, I do not see a buck controller on either the old board or the new board. There are no sanded components and nothing jumps out at me as a buck controller. Odd. Iāll have to follow the CSN trace and see where it goes from the sense resistor. I wonder if itās going through a current sense amp and feeding directly to the PIC. If so, we need a whole new firmware
Your new oneās from FT? My two shipped out yesterday ,I wonder which theyāll be.
I know about the good high res picās in the review, could you possible post a comparison shot of the two drivers physically sitting right next to each other orientated the same please?
Iām just wondering cause Iāll be ordering a PICkit3 this friday (I have 3 current projects centered around PIC MCUās, Iāll probably be pretty much completely switching here as soon as I can and redesigning the 17dd for the 8kb PIC MCU of my choice) but is the only reason for all this to be able to program these with no additional equipment from the other AVR programming we all do? Is the MCU not able to be flashed (with the correct PIC equipment) cause its locked or something?
First of all: sorry Cereal_killer, I have no immediate plans for more photos. Iām really off of taking pictures right now. Thatās why Iāve only been using my phone and only posting shots I deemed necessary. Also I donāt have a stock LD-29 available to put it next to.
That said, thereās really nothing you need to know that you canāt glean from what I wrote and the pictures I took.
I have no idea what the state of the PIC controller is.
My new one is from FT. Iām sure youāll get the same thing, the listing on FT actually says that itās the updated version.
I have not taken an in-depth look into the matter, but my current assumption is that the new version is just a simple refactor to make better use of space with the savings from going SO8 to SOT23-6 on that N-Channel FET.
May I ask what motivated your switch from Atmel to Microchip?
Hey man, can you post / email me the FW you have that gets the driver to run high only? I tried this (both as-is and after removing the STAR2_PIN=PB0 and references to it).
Also what way does the adapter go on? with the pin1 dot up and in the factory orientation and the 13A pin1 goes aligns with that?
Hey Cereal_killer, let me review the facts this weekend and make sure I donāt tell you a lie ;-). I havenāt worked on this in a little bit and Iām getting fuzzy myself. I have yet to install any of these PCBs (I have v6 and v7 in hand though). I just had the thing hard-wired, even worse than dead-bug style.
For now Iāll tell you what I think I know:
Orient the adapter PCB so that the BLF marking is against the LD-29 PCB. Orient the dot mark for Pin1 with Pin1 on the LD-29.
The code I linked to in the post you quoted is the last thing I messed with. IIRC I foolishly used the offtime firmware? I dunno. Definitely a bad place to start, ontime should have been used for this stage of the project - offtime is the next stage. Dumb mistake on my part, Iāll re-do it when I get back to it (this weekend?)
Somewhere in this thread I/we discuss how to turn the driver on. There appears to be both an enable pin and a PWM pin. Just pull the enable pin high or low, whatever I said earlier, and then pull the PWM pin highā¦ thatās 100% duty cycle, a state the stock firmware never allows AFAIK. Sorry for the brevity and lack of details, Iām pretty limited on the computer front right now.
I have measured the PWM frequency on LOW using the new LD-29 I recently posted pictures of. I measured the period to be 76us, which should be approximately 13kHz. This isnāt visible in the output signal, but we want to be in that general range w/ the output from our ATtiny.
My scope is not in good shape, so this is questionable, but it appears that the buck section is operating at around 444kHz (XM-L2 on the output, 8v on the input, medium mode).
I installed an adapter board on my old-version FastTech LD-29 today. I hooked up some airwires to the adapter and successfully enabled and turned on the buck circuit, as I would without the adapter board (Of course I had to use pin8 to pull 5 & 3 high). After confirming that that worked I moved on to installing an ATtiny13A flashed with nlite.hex
All our current firmwares do PWM on pin 6, not pin 5. Also, NLITE doesnāt know to pull Pin3 high. So in order to use NLITE we must install an airwire from Pin8 to Pin3. We must also jumper Pin6 over to Pin5.
0.8A 1.3A - 3.65A-
EDIT: 0.8A - 0.25A - 1.3A - 3.65A ā¦.apparently the star for moon mode is pulled high. No big deal, but weāll probably need to disable any āstarā functionality in firmware used on this driver.
EDIT: Apparently I forgot that NLITE features LVP. No big deal, with such a high voltage on Pin7 I doubt it will kick in. Weāll deal with LVP in upcoming firmware changes.
I will be doing this tonight man, thanks for the details.
Iāve never ran Nlite before, in the stock FW moon should be on (so the pin being grounded turns it off) or vise-versa?
Should stock on-time STAR work also?
Iām still happy to be working on this project for the good of the conunity but it sortāa feels like backwards progress for me having just received my PICkit last Friday itās strange to be removing a PIC MCU in favor of the ATTiny lol.
Heheh, well after a closer look, the normal Star2 is PB0, or pin5. Pin5 is where we put the PWM, so thatās interesting and all ;-). For NLITE youād normally pull Star2/PB0/Pin5 low in order to enable moon. We happen to be shorting it to PB1 which is probably low while the code initializes (before PWM starts).
Iād probably remove any extraneous inputs, such as star inputs, from the code. At least a couple of pins are pulled high by the driver for unknown reasons, plus we are shorting Pin5 and Pin6. You can compile the stock code and use it, but expect unexpected results in terms of star config.
After realizing what a pain it was to have PWM on PB0 instead of PB1 I took another look at hooking up PB1 to Pin5 of the LD-29ās landing pads. Turns out it does fit, I think, so while Iāve posted in the STAR thread for details on how to change the code, Iāll almost certainly release a v08 to allow firmwares which are closer to stock to run.
Well man [I believe] Iāve followed these instructions exactly as posted, Iāve compiled and flashed this but i get absolutly nothing, any ideas?
note I only have a new version of LD-29
Hm, not sure why its putting my writing inside your quote, strange.
