Hi, i am new, so no Beamshots at this time, but i have the TK70, HID75 Watt (Ebay) and the TN31 XML2. The HID does definately beat the others in throw.
However, if i was going to choose one of them, even for Throw and Flood, given you are a Newcomer like myself, it would be the TK70. The reason is simple, the first thing you will need to do if you are going to get into “Litium High Powered Multi Cell Lights” or even single Cell, is do some reading on the handling of Lithium Batteries Safely. You will need to do this as they are not the kind of Cell you can just throw in the Charger when empty and then throw in the Torch when they stop Charging. There is much more to it than that, and this Forum will be the place to learn how to handle them.
The TK70’s main advantage over the opposition is that it is not Lithium but it still puts out the Power of a Lithium Light, without most of the precautions (newcomer Safe). I am not aware of another Light that can compete with it on NIMH, and it throws with the best of the Lithiums still. If you want a first Light that you will have a very hard time trying to outdo, then this is your Light. They are well made and will take the knocks, so if you want to convince that Raccoon to let go of your Dog, Club him with it, it’s long enough to do this without putting your hands in harms way. The TK70 can be shortened to three Cells though if you wish.
The other reasons for it’s choice over Hid and TN, i would definately not wan’t to Drop the Ebay Hid on anything solid if it was Hot, let alone club anything with it, because the Bulb might let go. The TN31 XML2 does throw well but the Hot Spot is too small, unless you have perfect vision for Distance then this Light is best for finding stationary Targets or at least slow moving ones. You will have trouble trying to track an Owls Progess in flight with it, not with the TK, you wont have to have the Light directly on it to see him Clearly. It is great for Tracking fast moving objects at a Distance, and i wouldn’t be trying to fend of a Raccoon with a TN31 Either.
I’m almost certain that any of the Budget Lights will need to be Modded substantially to be in the race with the TK, and if you are new to LED, Modding probably wont be an option for you yet (as in my own case).
Don’t worry about the fact that going for such a Powerful Light in the first place will put you off further Purchases, as i doubt this will be the case. I started off with a TK70 & a TK35 and thought that should end it there (Both chosen as a result of advice from this Forum). I now have a Bookcase full of Lights (Mostly Lithium, also reccommended here), if you find LED as amazing as i have and most of this Forum do, you will need to buy a Bigger Bookcase for the Purchases you are going to make over time. For with Led, one size does not fit all, and this Forum is the place to learn what to buy on a Budget to stock your Bookcase. You will be awed by most of them, if not you can learn how to Mod them here. Even though you have the TK70, which is a hard act to follow. You will also learn all you need to know about High Powered Multi Cell Lithium Lights and the Safety aspects of them and Litium Batteries.
In short, for what you want the Light for and the Throw that you want, if you want to buy a Light right now (that is very hard to beat for the money), that wont require any Mods, that is Plug and Play (NIMH) with all the Power of the Lithiums top Contenders (just put Batteries in and go), TK70 is your Light. If you still want to go High Power Lithium first, then if you aren’t up on Lithium Safety yet, do some more reading and ask some more questions of the other people on this Forum First before you Purchase.
Hope this is Helpful
Cheers and Welcome to the Forum.
