Ive been playing with 97 CRI 100 watt Bridgelux RS emitters for a while and really enjoy the high color saturation. Its nice that more high CRI options are trickling down to the consumer market.
UV spectrum should be a warning to all, a slight CRI benefit is completely outweighed by the negative, if the price is exposing yourself to more UV spectrum.
Exactly.
My first thought, no thanks.
Eh. UV shmyoo-vee! I ain’t scared!
Just don’t shine it directly in anyone’s eyes - which you shouldn’t be doing anyway.
If you really want a scare, read up on Dihydrogen Monoxide! Another link here.
Dihydrogen monoxide! I confess I was telling to myself wtfits even before I clicked on that link, DavidEF. ROFLMAO!
Well, irrespective of the context…
Cheeers! ^:)
Well has anyone found some high cri BULBS?
Philips range for example?
XHP70 3000k 90+ CRI.
Just putting this here for you.
Thanks, it was already on my wishlist. :-)
The more universal .com link here: http://www.ebay.com/itm/2015-NEW-Cree-XHP70-30G-K2-Warm-White-3000K-LED-with-20mm-Copper-PCB-6V-12V-/371480092234
Cheers ^:)
The latest IKEA bulbs are over 90 CRI. Strange enough they do not advertise it, but it is there on the package. What I do not like is that there is a ripple on the output (only shows on pictures, have not tested the frequency), but then, all Philips and Osram bulbs have that too (but not my Yuji high CRI bulbs).
(apicture showing the ripple, left is a Philips bulb, right an Osram bulb)
I cant find a suitable driver to power this led to 12-20w of power. And a voltage of 12-14V.
Most drivers are 9-12V which is not enough, and above that most of them are 15-22V.
Something like this, but 12V could be a bit low for the XHP70? http://www.ebay.com/itm/Trasformatore-Alimentazione-Driver-220V-240V-a-AC12V-1A-per-lampadine-a-LED-/291188703546?hash=item43cc33013a:g:My0AAOSwwPtTwPpf Or perhaps not?
Perhaps there are better and cheaper with a more common voltage
What about R9 Joz? Any info? I wont use anything but R9>70 in my home ![]()
Will look for the in the local IKEA store and if they are awailable will post results
mdeni, you may want to peek at these: 3-4x3 W Watt High Power LED Light lamp Driver Power Supply 85-265V 600mA
600mA constant current drivers, with adequate output voltage range. With 3 pieces in parallel, ≈1.8A of driving current. Also, having multiple supplies gives you a redundancy reliability advantage: if one of the drivers goes poof, the light will just dim a bit, so you'll know its time to swap a driver.
Cheers ^:)
