High End TV Rabbit Hole / Display Tech is Bonkers
By “properly” I guess I mean that they captured what they intended to and audiences liked the results. So if something is obscured in shadow or out of focus, it was intended to be.
IMO wide color gamut and hdr should be a means to an end, with the end being a faithful recreation of the original. I don’t think you need to hit max nits in order for a disk to be considered reference quality. If you’re talking about finding a demo disk to impress the uninitiated, then yea a more modern film with crazy colors and highlights might impress them more but I don’t consider that inherently better.
Just watched the season ender of Law and Order.
Most/all(?) of it was done hand held – with no image stabilization.
In fact I’m sure they added extra “shaky cam” for artistic reasons.
Shot from like 2 feet from the actors face.
On the new 85 it was nearly unwatchable. Barf city for any motion sensitive folk.
Does no one actually screen this stuff before it goes out?
All the Best, Jeff
My thought is to have source material that will allow the full capabilities of the display to be demonstrated. I am not arguing that classic movies are not “good”. I have a large number of movies that would fit that description. Just that there is better material to demo a high quality 4k hdr wide color gamut display. If those characteristics are not there, then no one, initiated or uninitiated can see them. I consider most of the National Geographic/PBS/BBC nature discs (Planet Earth Series for instance) to be in the category that I use. Not that I want a steady diet of them… So I am not arguing at all about what is “better” for enjoyment or appreciation of artistic intent, rather something to really show off the capabilities of that new display that you got.
Both types will benefit from the technology, no question about it. But if you want to see what that display can do there is no substitute of something taken with 4K HDR wide color gamut cameras as the source and using high production values. It has been my experience that that kind of source never fails to impress anyone (regardless of their experience level) when displayed on a well calibrated set.
I’m currently playing a video game that has intentionally shaky video for the cutscenes.
The game is Metaphor: ReFantazio.
The shakiness bothers me a little.
I think the game would be better without the shakiness. :man_shrugging:
Disclaimer - before I continue down this rabbit hole, I want to emphasize that it is largely academic. If you buy a new TV these days, regardless of whether it is for the more clearly valid reasons of getting a larger screen, or getting the benefits of HDR and wide color gamuts, or getting a model with better black levels or better brightness than your current model, it is going to be 4K unless it is a relatively small screen. Of the 36 TV’s Best Buy currently has for sale in the 50 inch size class, only 1 is not 4K.
On the other hand, I would not buy a new TV specifically to get 4K, nor would I worry about spending extra money on 4K content unless you have a very big TV or sit very close.
Sure. And to do so, let’s all forget Jurassic Park. That was a quick anecdote, but the fact is it was a visual spectacle even in DVD resolution, and while it did look better at 1080, which helped my enjoyment to a degree, the returns diminish the further resolution increases.
If we’re going to be scientific about TV purchasing decisions, it is probably worth having recourse to scientific sources, rather than marketing sources. The marketers who plan Best Buy’s and Costco’s displays are very happy to have people inspect 6 foot wide TV’s from 3 feet away. You’re not supposed to think about the fact that your couch is 3+ times that far away, and the pixels are 3 times harder to see. The physiologists, on the other hand, have published their own work putting the resolution of the human eye at around 60 cycles per degree, and when you do the geometry on that, you get the charts in the RTings link I posted above.
https://www.cis.rit.edu/people/faculty/montag/vandplite/pages/chap_9/ch9p1.html
For a more personal scientific test, which I have also done, use high quality still images, and resize them, and view them from distances appropriately proportionate to screen size and resolution. If you correct for all of the factors, you can try this out on a regular TV monitor.
For example, I know from that if I view a 1080 image on my 24 inch, 1080 monitor from about 3 feet, it is roughly comparable to viewing on a 75 inch TV at 10 feet. It is very easy to compare DVD (480) and HD (1080) content this way by resizing a 1080 image, and comparing it to the original. Yes, you can see an easily discernible difference in this ideal circumstance, much more easily than with moving video, and you can be certain the source content is the same. Depending on your image editor (I use GIMP), you can also do what real TV’s do and re-upscale the 480 image back to 1080, reducing the perception of pixelation. You can even sharpen it, improving the edge acuity. Neither upscaling nor sharpening recover the missing detail that the original 1080 image has, but they can reduce the perceived visual deficit.
You can even simulate, if not the field of view, at least the pixel angle of a 4K screen by doubling the distance and again using appropriately scaled copies of the same image (eg - 1080 and 540 images at 6 feet on my 24in monitor have equivalent resolution to 4K and 1080 images on 75 inch TV at 10 feet). Of course, you can do this on a TV, too. It’s just not as easy to control the viewing conditions and switch back and forth.
To get to the point, what this test shows to my 20:20 vision is the RTings chart is effectively correct. I will clarify, however, that the perception of edge acuity can slightly exceed resolution. Comparing a 4K TV to a 1080 TV sized and positioned for a common 30 degree field of view won’t reveal more detail in the content, although there still might be a slight perception, under ideal conditions, or better sharpness of certain features, especially text.
Enlarge the screen or move close to replicate a 40 degree viewing angle per the THX recommendations, on the other hand, and the difference between 1080 and 4K content becomes more readily discernible.
But how many people actually have their living rooms setup like a THX theater? That would mean if your couch is 10 feet from the wall, you have a 100 inch screen
Just FYI, the Sony B9 has a reset settings option in each “picture mode”.
So that after I FUBAR the settings, I can get back to something sane.
I’m in the process of setting up a picture mode for the various source types and room conditions.
All the Best, Jeff
Honestly, seems to me like it might be a good idea to show one digitally shot Native 4k film and one perfectly restored classic when showing a 4K TV. I think both showcase something amazing that the format has to offer. To my mind, a restored classic is just as impressive and just as big of a showcase of the value of 4k, but I get why you would want to show the upper limits too.
shakey cam should be illegal :nauseated_face:
:point_up_2: :point_up_2: :point_up_2: :point_up_2:
Camera shake can be used effectively in limited circumstances, like in Saving Private Ryan or Children of Men.
But it tends to get overused as a very cheap special effect. Star Trek had already made it a cliche in this use even by the timethat show advanced to The Next Generation. But even those of us who love Star Trek recognized it as an often cheesy compromise. Worse is when excessive camera shake gets used primarily to confuse the viewer and distract from poorly implemented visual effects.
A little update on the Sony B9.
I really like it now that I’ve gotten the picture settings more dialed in.
Some things of note.
At first the image had a visual effect I couldn’t put my finger on.
It was like there was less depth of field. Well I eventually realized that on the old – smaller – TV the background looked “sharper” cause the details were smaller.
On the 85” the out of focus is more pronounced. Once I figured it out, it no longer bugged me.
Blooming? Nope. Brightness pumping? Not on mine.
Reflections in dark sceens? Yep. And they form horizontal streaks.
Regular brightness video - no problems.
My PT got one for New Years. He loves it. Got to be one of the best football TVs out right now.
IDK if other new TVs do this, but the Sony knows what the source is. Some, like Prime, will have a set of defaults that are optimized for that source. Can be changed if needed.
It also lets me do a setup for each streaming source. On set for Netfliks, another for Paramount, etc.
Very cool.
On the big screen motion judder and motion blur are more visible.
Judder is particularly annoying. I don’t give a rats ass what Tom Cruse or Spielberg say.
Turning off all motion control settings – for the “artistic” look is just BS as far as I’m concerned.
Let them watch their own stuff with herky jerky pans.
Found a video that explains it very well.
Watched “Carry on”. 4K, HDR.
Just frelling awesome.
Great plot, good acting. Only a little bogus tech.
Recommended, as is the TV.
All the Best, Jeff
Good to hear things are going well for you with the B9!
My upgrade was from 55" to 65" so I’m also noticing missing detail more. This week I watched I Am Legend and that Blu-ray looks pretty rough on the new TV. I was starting to think SDR blu-rays might be ruined on this TV, but the Train to Busan looked fantastic. I guess Blu-ray encodes just got a lot better over time. Part of me still wonders if I should grab the 55" instead so that it will be more forgiving of 1080p blurays. I have 7 more days to decide!
I can’t turn off the motion settings completely either. I find turning them up looks unnatural though so I try to set them to low or medium.
I’ve dialed the A95L in quite a bit since I picked it up but I’m still kicking around the idea of a professional calibrator.
Think I would stay on the 65".
Source material is only going to get better as time goes on.
Calibration is something I’m thinking about too. It would need settings for the various room light conditions. Perhaps for each source also.
I must admit that for regular TV shows, I like a little more pumped up image compared to watching movies.
All the Best, Jeff
Second vote for staying with the 65". I’ve been in this hobby for many years, from tube to projector to plasma and finally the brother of your OLED, Sony A95L 77", and going down in size is always a disappointment.
Do what’s right for you obviously, but it’s nearly always unanimous in video forum that bigger is better. One of the rare times that quantity (size) is almost, or as important as quality.
I’ve changed very little with my Sony settings and PQ simply the best I’ve ever had. But I know… YMMV. You’ve been to AVS Forum and check out the settings on the Sony thread?
Last night I was watching the Blu-ray of the film Knowing (2009). In the first chapter, there are several scenes where Nick Cage’s face is half shadowed and he moves it expressively. When this happens, it appears that the dark side of his face “lags” and takes time to catch up with the movement of the brighter side. Naturally I was freaked out thinking I’d discovered a serious motion rendering issue on the new TV. But after the movie I grabbed a vanilla Blu-ray player and plugged it into my computer monitor and was able to see the same visual artifact. Very strange! I haven’t found any reference to the issue online. The movie looked pretty sharp otherwise.
Thanks for sharing. I have this observation that digital device either for capture (camera) or for displaying (TV) are not meant for low brightness, where signal to noise is low. Don’t know if it’s always right though. Thankfully for some strange reason (as I tend to be extremely nit-picky with hobbies) this problem of TV display at low brightnest doesn’t bother me. I don’t look for it and it’s the bright scenes that I stare.
I don’t know what the cause is, but I’ve never seen anything like is before. I could understand missing detail but the way Cage kept leaving half of his face behind for a split second was bizarre. I don’t think that the explanation could be as simple as the camera being digital because digital cameras are used all the time and I’ve never seen this weird effect before.
Edit: Knowing was shot on a Red One 4k digital camera. I was curious what other movies I had seen which used the same camera since that sounded familiar. I ran across this first-party page by the camera company: Shot on RED
It has been normal for that to happen to Nicholas Cage ever since filming Face Off. It happens to John Travolta, too. The special effects department was so preoccupied with whether or not they could, they didn’t stop to think if they should.
More seriously, I have seen an effect similar to what I think you’re describing on over-compressed video. Because video compression occurs both spatially, like with JPEG’s, and between successive frames, really high compression levels seem to sometimes cause features to partially carry over into frames they don’t belong in. Furthermore, if they start to compress the color depth, it seems like color blocking issues show up in dark areas, first, which can make this compression lag more obvious.
But none of that should be happening on a Bluray. If it’s happening on multiple screens and multiple Bluray players, it sounds like it is a problem with the source material itself. I’m at a loss as to why, though. Maybe they shot it too dark, and somebody on the editing team got carried away trying to recover detail and maybe didn’t notice they were introducing weird artifacts in parts of the scene because they were under pressure to complete the edits and only watched a few snippets of the result?
Or if this is a psychadelic movie (I’m not familiar with it), maybe they thought they were being artistic?
Very weird - but hey, its Nick Cage. I too suspect some kind of compression monkey business.
On another note my PTs new 85" Sony is having mysterious power problems.
Random reboots and shut downs.
When the shutoff happens, it will not power on again using the remote.
He has to disconnect it from the mains to bring it back to life.
It’s in the 15 day time, so he’s going to request a new replacement from BB.
Hopefully they will make this pain free.
All the Best, Jeff
I moved to a new house in October and bought a Samsung S95 65”, mostly because it’s the only OLED with a non-glare screen (the room it is in has a skylight and French doors bringing in lots of light and reflections.
Samsung released a new S95F at CES that should be 30% brighter, traditionally the Achille’s heel of OLED.
