rickw12
(rickw12)
June 7, 2018, 2:33am
41
Thanks. I’ve seen that one. Lights with two switches like that don’t make sense to me. But taste aside, I need to avoid that kind of thumb action as much as possible.
moodysj
(moodysj)
August 16, 2018, 1:42pm
42
Not necessarily. A Energizer lithium ultimate primary L91 AA is a different animal than alkaline. A light behaves very differently on it vs an alkaline. So it is an AA and gives much higher output than an alkaline AA. In some lights, it even outperforms a NiMh
moodysj
(moodysj)
August 16, 2018, 1:46pm
43
WalkIntoTheLight:
ChrisGarrett:
They spec 5A and the Eneloop Pro (and equivalents) can handle that for limited runtimes.
You’re not getting long runtimes at that current, but it’s better than anything an alkaleak can handle at that draw.
Chris
You don’t need an Eneloop Pro for the Zebralight SC5w. I use regular Eneloops, and they work just fine. It will put out 500 lumens on a regular Eneloop for about 20-25 minutes. Cumulative run-time on 500 lumens, because you have to step the light back up to 500 lumens every 3 minutes. You have to do that test with a fan, or the light would get too hot.
You obviously get much better runtimes and efficiency on lower modes, but it’s nice to have 500 lumens when you need it.
As for other brands than Eneloop, they probably work fine as well, as long as they’re based on the same tech. There are lots of Eneloop clones. I’ve never used any of them personally, but many people swear they are identical.
Alkalines won’t get you the 500 lumen output, of course. Stick to 100 lumen lights if you require alkaleaks, or just never use the higher modes on brighter lights.
Energizer ultimate lithiums will get you way over 100 lumens
vit55
(vit55)
August 16, 2018, 2:03pm
44
Solution is Manker T01II 500 lumen on AA throw 282 meters no expensive like Zebralight.
