No, they really don’t. For the comparison to be fair, you should be comparing bare cells of each type:
They are better (assuming you’re happy with decreased runtimes), but there’s no destroying going on. And the Sanyo cells still perform better toward the end of the discharge, which is right about the point where a linear driver will drop out of regulated mode because of the voltage drop. And since at the beginning any excess voltage is just burned off as heat anyway, the Sanyo cells will generally still be better for maintaining maximum brightness for the longest possible time.
Also note that if you rarely discharge your cells very much, then everything is about equal all round.
EDIT: By the way, those Orbtronic cells that HKJ has tested, and that are shown in the graphs here, are indeed PF cells. See the full review for details: Test of Orbtronic 18650PD 2900mAh (Black)
The panasonic PF would be your best bet. The only difference to the now discontinued PD version is slightly higher capacity (something like 20mah) and a ‘safer’ chemistry. Not sure how much safer though.
Also the Orbtronic PD is actually a panasonic NCR18650PF battery, not the PD version. Orbtronics has simply re-wrapped it and added a protection circuit. If you desired a protected NCR18650PF that would be your best option.
IIRC (if I remember correctly) from your posts you only use protected cells.
PD/PF’s with protection circuits……are very rare, like hens teeth….
I personally do not go with the hysteria surrounding the safety of these cells and the absolute need for protection circuits as a lot of people contend. High drain cells and especially ultra high drain cells and protection circuits are IMV (in my view) are not that good together, so I would not consider buying any with that feature. Mind you I am only talking about high quality cells.
I found this cells, i guess they are the best option? they even beat handly the Panas PF….wow. Are they safe? anything you can tell me about this IMR Keepower? do they last around the same period? build quality? thanks.
I just realized that the two modded lights you mentioned use a 2S2P 18650 configuration, so no single cell is going to be putting out anywhere near 4.5A. This renders your search for IMR cells, for this application, essentially fruitless, because you’ll be giving up runtime for no increase in brightness. In fact I’d argue that this would be the case even if you did have an application that required 4.5A per cell, since the heat generated by significantly overdriving an LED can actually decrease brightness very quickly, and the only real way around that is to solder the LED to a solid copper block or something.
TL;DR: stick with standard cells for the extra runtime.
