Can’t post a pic at the moment but I can describe. Feels much slimmer but the bodies are similar in size at the lens and tail. As already posted, mostly the the snagging parts/fins are gone so it is more comfortable to me. If you’ve seen the SK68 that someone turned down to remove the fins (I loved that mod), then I imagine that is a pretty good comparison. The SK68 is shorter by about the amount of the tail cap that shows when screwed in.
My guess is the wider beam of mine may be a function of the lens used, which could vary by manufacturing run.
You might not need it, but if you’re in the habit of sometimes gifting out SK68s as I have, then you could buy one of these to give away another SK68.
Unfortunately I’ve misplaced or lost my XPG SK68 so I might like another version with XPG or XPL and a different driver but it would be for a useful pocket light and not for pushing more amps.
Has anybody come up with a driver that runs on NiMH and Lion like these lights come with but having better modes? If not, I might just pick up a few more samples over time to hope for a little higher draw (say about 6-8W with Lion) than my sample has.
On the other hand, this weekend I destroyed two Nanjg 105c drivers trying to file them small enough to fit them into a tiny 14500 zoomie. Sucks, since previously I was able to do this twice without problems. But when I tried this weekend it killed two drivers.
Now I’m thinking filing 17mm drivers to fit in 14mm spaces isn’t a good idea. Anyone have the link to that BLF sk68 driver?
Thinking I’ll also need to get a cheap hot air gun. Soldering iron is fine for reflowing emitters on stars or removing 7135 chips. But it’s not a good way of swapping the ATiny13a microprocessor.
