I haven’t tried that yet as I feel the 87V is pretty close. My numbers before the resistor mod, pretty much resemble clientequator’s at each mode and jumper setting.
I may end up buying a clamp meter, but I think I have hit the upper limit with this driver. If my math is correct I’m guessing around 55 watts in.
This project is easier to solder together than Gxb172. The hardest one is soldering the tiny mosfets on the led board. The rest is easier than Gxb172. I am not sure why schizobovine have problem with battery, since mine work first time.
Same as Gxb172, I recommend to use magnification to solder with smaller solder tip, thin solder wire. I only use hot air for the lfpak33 mosfet.
Before assemble, I suggest to make sure lfpak33 have no short, battery have no short, and led light system voltage working with power supply. For me I use oshpark 0.8mm pcb for both and they fit Convoy S2+ good.
I recommend the hobby maker to order more tiny mosfets before you blow them on the floor, and I recommend making sure you buy the correct Convoy s2+ light to make sure it fit the stainless steel switch! Make sure you handle tiny battery carefully! Also I use very thin wire (awg30?) to solder + and - pad together. I make sure I keep the switch screw tight, but not overtight to prevent pcb from breaking because it is not as strong as aluminum washer.
Difficulty - 6/10
Cost - 5/10
Result - 9/10! Very nice! I remove one point so it is not perfect so loneoceans can motivate to improve it
I recommend loneoceans add more led on the tail to make ring of light, but I understand how it may have no space since need two bank of leds, and any smaller is harder to solder.
Final bonus photo of S2+ in snow! I am disappointed because it didn't melt all the snow , but flashlight make the snow light up very bright from inside!
After using this light a while, I think actually I mostly use 'low' and 'medium' mode the most. Moon light mode useful during night-use and the ramp help to prevent blinding me. The turbo is too bright and only useful to show off to friends, but still a fun project!
Big thank and appreciation to loneoceans for this cool project and for everyone here who also make their own and inspire me to build this successful project!!
Thanks for this thread, I had been on Loneocean’s site and the gerber files dont seem to be there nor the firmware, etc only the schematic.
Ive found a github link for the firmware, but still reading up on whats required for the build.
Are all the modes set by jumpers? You dont need to modify the code to set your custom brightness levels?
Im up for the challenge to build one, ive done SMD work before, but I will get a bunch of boards made from JLCPCB, they also offer an SMD assembly service, so if thats cheap enough, I may as well just get them to make me a bunch of boards.
Loneoceans also is the same person who designed the universal driver 2.7 revision for a DRSSTC, (musical tesla coil) I have built one using his driver board and it is of excellent design.
Thanks Loneoceans if you are reading this
This is Loneoceans thread for the GXB172. [ GXB172 - 50W Single Cell 17mm Boost Driver! ]
The mode groups can be changed by 2 jumpers X1 and X2. Their description of the settable mode groups is on Loneoceans GXB172 page on his site.
Its about 3/4 the way down the page. Any of the modes can be changed in firmware by adjust the value anywhere from 8 to 1024 I believe. Seems like it couldn’t go any lower than 8. You’ll have to experiment with the low setting.
Yes I had been on that thread, I got stuck on the wrong page of his website, i was looking on the GXB17 page instead lol
Right now im figuring out what the best way to reflow the parts on the board. Did you use a reflow gun or an oven?
I have neither of these.
Ive ordered a USBasp USBISP and will design a jig for the programmer probes that can be 3D printed.
Does anyone know of a service in china that can just do all the SMD work? It will take some time to assemble a single board, and I probably will want to make several for myself.
I see JLCPCB can do this, but only on one side of the board. Im tempted to get a batch made and work out a group buy or something similar.
There definitely is a market for this driver if we can get enough people to buy the initial production run, I could get more made at a better price.
That would be great, I would definitely be up for a few of these drivers (the GXB202).
The cost of making these locally here in the States is quite prohibitive, think almost 3 Grand to get a hundred done initially.
$3K is actually quite cheap considering it works out to $30 per board at that price and would cost me more than that in parts to make a single board.
Im sure we could get the price down far more if someone in china can help out with production, either way, we will need a group buy to fund the initial production run and still will require labour to program them all.
I wonder if Mountain Electronics are interested in stocking this driver?
Im on PCBway getting a quote at the moment and its about $440 for the boards and assembly costs, but have no idea on component costs yet as im trying to get the right format of BOM file sent to them as well as a centroid file which I have no idea how to make from the gerber files.
If ya got the files from OSHPark, just send them the whole ZIP file, they can work with that and make the paste stencil out of it as well, it’s all there. My local quote for all the parts was about 1500 bucks, and at least through Digikey, I can get them to preprogram the MCU before they send it to me.
Now that I am thinking about it, it might be most economically viable to just make the 12V version, since it will cover all the bases in one go, at least when it comes to the Cree LEDs
Thats good to know Digikey can program them. I dont think the person understood what I was trying to tell them from the PCB company. It wouldnt let me upload the gerber files alone (i did upload the whole zip file) but wanted me to add a BOM file and the centroid file before it let me click submit, so ive been communicating over email.
Anyway, ive been in contact with loneoceans and he will be able to help us out with the required files.
I've sort of followed this thread from time to time. Nice to see it is gaining some momentum towards getting a production batch made. So go ahead, make my day. :-)
Is the 12V version able to drive 2S/6V emitters equally well?
Concerning power input, other 12V boost drivers can be fed with 2S cells. Thanks to a much higher input current, with 2S cells the power at the emitter would reach ludicrous levels with this driver. Is this feasible? LoL!
Not gonna buy anytime soon but since this initiative is in its early stages, count me and my axe in. :-D
Let me know how many you need.
Once I get price confirmation, I will go and start a new thread to feel out how many pre orders we need, likely the more we can do the cheaper we can get the costs down, but at a guess, we should be able to get the unit costs well under $30USD per board im hoping.
for 2S lights, mountain electronics has a very good driver already that can be ordered with custom firmware. but as far as 1S lights goes, this is the only real decent driver I can currently find.
Considering the fact that I can build them locally here in the States for about 25$ apeice, that should not be a problem.
Hell… If I would have garnered any interest, I would have plinked down the initial cash for the startup, already got a local quote and everything ready to go.
Anyhow…
Personally would love to have a Convoy L21 with a 70.2 popping in at 6K+
KnHawke that’s great idea starting it up.
Well any of you guys with skills to make them i’d be happy and i’m sure a dozens people who expressed their interest so far.
OK, heres an update, im currently in contact with the manufacturer in China and getting quotes.
I want to ask the community a few questions, so I have started a new thread on this. http://budgetlightforum.com/comment/1610677
wow this is a great news! Thank you to Nzoomed, for helping to make this group order! It is right that when making this driver, small parts are challenge to solder, so it is good to have professionally soldered driver if people do not have small soldering iron and tools!
