Alright. Do you have any experience in mixing different AMCs? Like 4 380s and 1 350?
Nope, I have a decent stock of the 350s and since the new board with the 380s has a different micro controller that is not compatible with my programmer I won't be using them until Tido or someone else figures out a way to reprogram the new boards, sorry.
http://www.mouser.com/ProductDetail/Cree-Inc/XMLAWT-00-0000-0000T6053/?qs=D3QG1iK7FqjQo2CUn%252bWiImdOGYyXm8ye%2FmqWnMCq920%3D I’ve been look a lot but you can find them if you don’t mind putting them on a star yourself. It claims to be a 5000k though I have not ordered one myself.
I'll save you the trouble of reflowing, here are some 5Ks ready to go
Thanks ill have to keep these in mind for when I start making my own.
Pro what exactly is your profile pic?
Welcome to BLF, promythiest!
Thanks, learned more in the few last week about DIY than in the last year.
KD seem to have changed the way they index their products, and as such your links to their listings are all broken. Whenever you get the chance, could I impose upon you to update the links? I’d really love to have a go at putting together my own drop-in. It would be much appreciated.
Thanks
Never mind. I stumbled across old.kaidomain.com, which they are obviously keeping up for now. As such I was able to find the SKUs.
“Old” links:
http://old.kaidomain.com/ProductDetails.aspx?ProductId=11201
http://old.kaidomain.com/ProductDetails.aspx?ProductId=11088
http://old.kaidomain.com/ProductDetails.aspx?ProductId=1745
http://old.kaidomain.com/ProductDetails.aspx?ProductId=11130
New links:
The Nanjg 105c 2.8 amp driver doesn’t seem to be available anymore (although there are plenty of others), and I couldn’t find the right isolator sheets either. Everything else is below:
http://www.kaidomain.com/product/details.S009942 (P60 empty drop ins)
http://www.kaidomain.com/product/details.S009877 (cool white XML 1A on 16mm star)
The isolators can be found if you search for "isolator" on KD. There are several different ones.
Or maybe these:
http://www.intl-outdoor.com/cree-xml-led-reflector-positioning-gasket-10-pcs-p-457.html
http://www.intl-outdoor.com/cree-xml-insulator-gasket-10-pcs-p-463.html
If you need a reflector for every dropin you can use the empty one from KD or maybe this one if you want to choose between smooth and OP:
Sources for LED are numerous.. the Nanjg 105C can be bought at illuminationsupply, intl outdoor, cnqualitygoods..
You can also just buy the pill only:
http://www.cnqualitygoods.com/goods.php?id=1400
and the big spring:
and the small spring for the driver:
http://www.cnqualitygoods.com/goods.php?id=1127
Generally, you will find almost anything you need on IO, IS, KD or CNQ. :)
Dont forget some thermal glue, solder and probably wires (although most drivers come with wires, sometimes they are crap).
Thank you very much for all that NightCrawl. Much appreciated.
I shall now stumble my way through the decision making process, and hopefully emerge with a freshly built P60 drop-in in a couple of weeks or so (which will mostly be waiting time).
Thanks Nightcrawl, I’ve been looking all over for those springs. Eric, do you have a list of the flash programs you can implement on the Attiny 13A drivers?
Sorry I don’t have a list but if you read Tidos thread I can do any of the shared programs in his thread plus the 5 mode I have.
So, you want a flashlight with modes that are just right but can't find the one, no matter how hard you look? You are especially craving for a light that can be programmed with light levels ranging from hardly visible to full blast can't-see-anything-but-dark-spots-for-a-few-minutes when accidentally shone into your eyes? Onna stick In a P60-style host? Well, today's your lucky day. Building It First, you will need to organize a few parts. From left to right, the NANJG 101-AK pimped with a four…
Great, I was unable to download his driver and haven’t gone through the thread to see if there is a list or link elsewhere to one yet but I’m looking for 2 mode groups for a dive light: Lo-Hi and Lo-Beacon(.2Hz, 5 second delay)-SOS. I’d like the second group (emergency modes) accessible but not in the “regular” cycle and less cluttered than stock set ups. Anyone seen anything like this?
