Don’t laugh, this is probably going to be one of the most valuable threads on BLF. I like that we finally are seeing reviews that are not only honest but bring out the real negative characteristics in lights and in companies. I am real tired of seeing the overwhelmingly positive reviews that talk about foolish things like “well greased threads” and how the “style and finish is nice.”
As others have mentioned, thanks for the integrity and the honest review. I just need to remind everyone that name-calling and personal attacks are completely off limits on this forum. Please go back and edit or delete your posts if they have anything that goes against these rules:
On mine loosening the head a couple of turns or taking the TIR out and going mule/commando mode removes pressure on the MCPCB and allows the light to be in an off state.
There’s a thread on TLF where one user was able to fix this problem by recentering the driver PCB.
Of course, such problems shouldn’t be there, and one other manufacturer seems to not have them with his lights using an inner signal tube. A few dollars more expensive, but a whole different class quality-wise. So thanks for the review . And for this easter egg: Not again, please.
This is also expected behavior when you have a short to ground caused either by bridging solder between the negative and heatsink pad under one of the leds, or when you have the negative driver wire touching the side of the star which also creates a bridge from negative to ground.
In both cases, you get connection that bypasses the driver through the star. But in order to have a short, the star must then have an electrical connection into the head of the light. Without pressure on the star, the star tends to ride up on its thermal paste and not create a good electrical connection. But when you apply pressure to the star by screwing in the bezel completely the star is pressed through the paste and an electrical connection is achieved.
I haven’t tried removing the star in the FWAA to see if the shelf is anodized or not, but even if so electrical connection could still be achieved by the star touching the head of the screw that is installed to prevent the star rotating during assembly. The result is the same… pressure is needed to create the connection.
Had this same problem in a DQG Tiny III I modded a few weeks ago.
From that picture it looks like the shelf is anodized. The white stuff all over it is thermal paste. You can tell from the picture that the white is not bare aluminum by looking at a bit of the grey anodization on the shelf to the upper right of the screw.
It appears The_Flashaholic is getting a short to ground either under one of the LEDs or where the negative driver wire passes through the hole in the star. When the star is firmly in place, the edge of the star presses into the screw in the top of the picture. That screw passes through the anodization and creates a short to ground bypassing the driver.
Most modders can probably fix this without needing to return the light by doing the following steps:
Inspect where the negative driver wire passes through the hole in the star. Does there look to be any chance the bare wire is touching the side of the star? if so, desolder the negative driver and lift it up with a tweezers then resolder.
If not, the problem is probably a short to ground between the negative pad under one of the LEDs and the central heatsink pad. Remove the star, reflow off the LEDs. Inspect for excess solder and reflow the LEDs back on.
I’m surprised Lumintop contact anyone, any time I message them it hits a black hole.
I had an ODL20C that wouldn’t charge. They’re charging outrageous prices for the lights on their website (anywhere else is cheaper)
People crap on Fireflies, but they’re better than Lumintop any time.
The brand deserves to be damaged. They have made some nice lights but over the last couple of years and especially lately I’ve gradually lost any respect I once had for Lumintop as a company. It seems they themselves are doing more damage to their brand then any reviewer.
I like small and powerful lights even with their limitations but I held off buying the FWAA until it’s offered by a reliable seller. With quality issues coming to light I might be waiting longer if I buy it at all.
I have eight Lumintop lights, no problems. Three FW21a Pro vn, FW21a Pro 3 x 90.2 vn, two BLF GT94, FW3a W2 vn, and FW4a W2 vn. No problems, all good.
Honest reviews by The_Flashaholic: I look forward to his reviews; it has been that way for more than a few years. About four years ago, when I was super excited about collecting Acebeam lights, he did a bunch of positive reviews on various Imalent lights. I waited until the Imalent R90TS came out, and then I got excited about Imalent lights, but then he began pointing out issues with Imalent lights. My five Imalent lights are all good, except the MS18 battery pack takes a long time to fully charge. So, I plug it in, deal with surviving on the surface of this earth, and when I can catch my breath, the pack is charged. I can't complain. So many things on earth are much worse.
I have had great results with the 49 performance lights that I have gotten from Acebeam, Imalent, Lumintop and many other makers of routine/nice quality lights. I should be happy that the many negative general advisement posts and threads that target so many makers of routine quality lights have not been confirmed by my happy experience.
I like reviews that are not 99 and 44 hundredths percent syrupy sweet. Tell it like it is with the sample that the reviewer has is ok/fine with me.
The first one I plugged in a battery and it had connection issues out of the box. With the head removed I tightened the tail some more and its been fine since.
On the other side, and I have been on the other side recently with the Thrunite TN42 V2 which came supplied with heavily modified 21700 protected cells that had a negative contact on the positive sides, and longer than normal center pins. That configuration if allowed to remain makes the battery proprietary as shipped, as no 21700 cell in my arsenal would work without magnets. Since the negative post on the positive side only contacts a plastic insulator, it serves no function,which is idiotic and I said so. I recieved several responses questioning my ability to identify a modified battery, and I was an electro-mechanical technician before being disabled, so I know batteries. I did finally remove the taller insulating ring that prevents standard orbtronic 21700 protected batteries from working and even posted pictures of such, which might have killed my warranty. I also added insulators that are sticky on 1 side to cover the ill conceived negative contact on the thrunite batteries.
For all my efforts someone suggested that the propriatary nature of the cells was overblown now that pictures of the easy fix existed…but I CAME UP WITH THE FIX AND POSTED THE PICS. I do not think the fact that I risked ruining my light, voiding my warranty, to fix the Thrunite issue that should never have existed means the issue of proprietary batteries was overblown. At least the O-light negative on the positive side serves a purpose with magnetic charging or remote tail switch activation. I felt I was making an honest attempt to make the forum members aware of the issue, and once I found the fix, I posted such. I will admit the post saying the issue was overblown kind of ticked me off, since the end customer should not have to modify their lights to allow the use of more readily available protected cells. If however Thrunite were to pay me for MY mod of their batteries and insulator ring, and assure me my warranty would be intact, I might then pull my unflattering review. All else on the light seems good,
Right or wrong there seems to be a great deal of brand loyalty on these forums that make users loyaly to the barands when they really shouldn’t be, especially on a 210 dollar light after discounts, Try not to assume the reviewer can’t or didn’t measure his cells. 1 cell brand being an issue is expected, but 3 seperate brands is unacceptable. My point is Flashaholics attacks came after his review, suggesting that he did not know how to choose a proper cell, which is insulting. That is what prompted the smarmy remarks. PS…My fix of their idiotic design does not make the design less idiotic, as shipped by Thrunite.
