How did I trip the Protection circuit on Ultrafire 3000mAh 18650 with a DMM?
the panasonics look far from discharged at 3.6v.
maybe i was remembering wrong lol… but i could have sworn i had them down that far before.
Why is it safe then for the Panasonic NCR18650 cells to go down to 2.5v’s if there is no power left? I do not understand?
Resting Voltage vs. Under-Load voltage. Additionally, There is power left - it is not ZERO percent. There is just not much power left - not enough to do anything very productive with.
PPtk
Thank you for the response. According to the table above, at 3.2v, the cell has nothing left. I just wonder why Panasonic would state that it is OK to take the cell down to 2.5v? Does not seem safe or good for the cell.
The above voltage is unloaded, when loaded you can get considerable lower, depending on discharge current.
You can see that on all my battery test curves.
Thank you HKJ. And PilotPTK.
Thanks for the offer of the formula :slight_smile:
It seems a bit too involved for me, unfortunately, though…I’m the type of guy that just knows that Volts x Amps = Watts. The Rint and Isc stuff is a bit above my head, thanks all the same :slight_smile:
You’re welcome. :slight_smile:
