How many Emisar D3AA have you ordered???
Now I also boarded the choo-choo hype train, with one.
  • red
  • warmwhite switch
  • 4500K 519A dedomed (should give roughly 3200-3500 K CCT with negative duv)
  • with magnet and extra tailcap without magnet, stainless steel bezel and both additional optics
Maybe the size and handling of D3AA can replace my TS10. In brass it would be much nicer, but maybe in the future…
@ToyKeeper are there some surprises in Anduril like additional modes or changed UI elements or is the UI the same as with other recent Emisar lights? (Except for the battery performance check at the beginning of course)
Waiting for a copper head to order another one…
I asked Hank, no special metals version planned any time soon.
Well Hank will just have to wait accordingly for a second order then… He’s probably busy enough with the new lights for a while anyway.
That’s unfortunate.
Then I will stick to only one D3AA. I have enough lights made of ordinary aluminum. That’s fine, I will wait accordingly :smiley:
Same here
Copper for sure :sunglasses:
1
Cyan
519A 4500 de-domed
None
If Copper were to be available, I would go for a Domed and De-domed 519A
Did Hank say that to someone?
No, as I wrote it was rough assumption based on order numbers. But now as a lot of orders are delayed it might be true.
I have 2 Emisar lights and one Octigon but to be honest don’t like the new models with the white button. I understand why, but just like a black button and those are not available unfortunately, otherwise would have ordered one
Have you emailed Hank?
JLHAWAII808.COM has them, so I imagine Hank still has some as well.
Emisar/Noctigon replacement Switch Ring/Button – JLHawaii808
Hank ships accordingly. Sometimes with parts that are not on the menu. I second the recommendation to ask Hank unless you would rather deal with Jackson. Either way, black buttons are pretty easy to obtain.
  1. waiting for all the problems to be ironed out.
fwiw, this post gives the O Ring dimensions:
If you need replacements (Nitrile), they are available on Amazon, or you may also be able to find them at a local hardware store.
There are no other issues Im aware of w the D3AA. Except some people dont like the pocket clip, the diameter of the head, and the sharp corners around the switch pedestal, but those things wont change, they are what they are.
Is the Copper switch retaining ring upgrade for the D3AA available in flat version? Most pics I see posted is the raised type.
You are tempting me to put a L91 in my D3AA just to see a white voltage readout :smiley:
Anyway, thanks for continuously improving the Anduril UI. I really like some of the newer features.
I’ve managed to hold off so far but I have $40 burning a hole in my pocket so I’ll see how long I can last.
Zero. I would have one like kr4 style and double channel variable tint (+ red led if possible)
I bought 1. Had my usual problem with the Hanklights, I don’t know my LEDs very well. So I went safe and bought a couple of optics to play with. I’m not after much in the way of throw with this light, more a bright hotspot and a smooth transition into flood.
Emisar D3AA 14500 EDC LED FLASHLIGHT
Color
Cyan
Switch retaining ring type
Flat version
Switch backlight color
RGB
LED & Tint
519A 5700K with dome
Please choose
Additional clear 10507 optic, Additional frosted 10508 optic
