The NANJG’s firmware can’t be read out since it’s protected against that. There’s no error message, but trying to read it out only results in garbage data.
So, how am I supposed to return genuine nanjg software in case I mess up something? Or even how to delete/overwrite it then!!! That means that once the sw is changed there's no going back, mode selection, soldering different stars with BAT- becomes useless!!!
mattaus - I get the same error/warning message every time: "cannot set sck period" - ignore it, it still works as long as you get the device signature message and the downloads verify. Sometimes I got to play around with the clip positioning, other times it seems to work better at the 5v jumper setting, sometimes at 3.3v.
Sirius9 - yes, there's no going back, but why would you ever want to? The luxdrv 0.03 is far superior and the biggest loss of one driver is like $2.70 (FT prices I pay at qty 5). I've never had a download failure yet and I've done at least 20, maybe 30. Buy the cheapest 2.8A Nanjg from FT (amc7135-2-group-25-modes) - I keep ordering in qty 3, then 5, and keep running out of them... Seriously, I don't consider this any risk at all.
I’ve used usbasp from Fasttech too (on Linux though). At least my devices are not lemons. Fasttech jtag debugger works like a charm with Avrstudio on my virtual machine as well.
The usual reasons for programming failure for me have been: bad contact, incorrect pin connection order, too fast programming clock and noisy signals due to too long cables (where lowering programming clock rate may help). (Assuming the programmer is not a lemon and the software is in the working order).
Driver is NANJG101-AK-A1. I can’t get ID for attiny13 and I tried tens of times so no go for programming (tried 5v and 3.3v). Then I removed attiny13 and put it in the clip and it worked perfectly, could read it 4 times in row.
Second driver is NANJG AK47 which I can access once. So I have to plug off the UASASP and plug it back in if I want to to anything else to attiny13. Reading it 2 times in row is impossible. Didn’t try removing the ic but I guess it would help
forgot to add that I compiled the code with raspberry pi with installed gcc-avr avr-libc
If you have star 2 connected (pin 5 of the micro) connected to ground (also pin 6 or pin 7), it won’t program.
Also, some drivers have a filter cap on the battery voltage divider bottom resistor. The chip won’t program if it does (or might program with a very slow ISP clock).
DrJones has been helping me with this however it appears that he is very busy these days so in an attempt to bug him less I'm going to see if anyone can help me here
I have some code that I want to use on an ATMEL 25V. It's proven to be working with a 13V. DrJones believed that the code would more or less work on the 25V with 2 minor changes to get voltage detection working. Anyway, his last comment on the matter was to suggest some fuse settings:
(clock runs at 1MHz then, in AVRstudio: clock:8MHz-RC and check CKDIV8).[/QUOTE]
Now it is important to note I know nothing about ATMEL programming - this is the first time I've ever attempted writing new firmware to an ATMEL chip (I finally got hold of an ISP programmer that works!!!!).
So using what information I could get from the flashlightwiki I entered this:
Now that appeared to work until it got to the high fuse:
[QUOTE]
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xFF:
avrdude: load data hfuse data from input file 0xFF:
avrdude: reading on chip hfuse data:
Writing | ################## | 100% 0.01s
avrdude: verifying …
avrdude: verification error, first mismatch at byte 0×0000 0xff !=0xdf
avrdude: verification error; content mismatch
avrdude done. Thank you.
[/QUOTE]
So 2 things:
1) How can I fix the high fuse issue?
2) What is causing the high fuse problem?
3) I didn't even think about it last night, but what should I be doing with DrJone's suggested extended fuse!? I completely missed it lol.
I'll start reading up a bit more and see if I can find something helpful elsewhere on the interwebs. It might be important to note that DrJones' suggested changes to the code have not been made yet. Just in case they could help rectify this issue his suggestions were:
[QUOTE]58: #define ADC_PRSCL 0x06 // ADC prescaler of 64
---> #define ADC_PRSCL 0x05 // ADC prescaler of 32
EDIT: I'm using DrJone's Luxdrv firmware now and have learnt a few things reading through that thread - namely how to use AVR Studio 6 lol. I can compile code now, and for the 25V at that, so now I just need to work out how to make it work for me...
Will do. The pin layouts between the 13 and 25 are identical so as far as I can tell you should be able to readily compile code written for the 13 to run on the 25. Fuses may be different but I know sweet F.A. about them at the moment!
My issue now is that I think (haven't had the opportunity to check yet) that the pin associations on my PCB are different to what you typically find on the KD/DX boards people use here. I'm hoping at least a few a similar. My board has:
Voltage monitoring on pin 7 - VIN to a 3k resistor, sensed on pin 7, and 10k resistor to GND.
Temperature monitoring on pin 3 - Vref out of pin 2, into a 10k resistor, sensed on pin 3, and a 100k NTC thermistor to GND.
PWM out is on pin 6.
Ideally I will just modify the luxdrv firmware to move functions to different pins (if required) and to work with my particular components, but as yet I have no idea where to start.
I'm sure i'll be back here in the coming days begging for help lol.
No, one nasty difference between the TINY13 and TINY25/45/85 is the register value that you have to write to select the 1.1V bandgap reference for the A/D converter. Atmel could have easily made the registers compatible, but they screwed up…
The TINY25 does have an internal temperature sensor, you could use that instead of an external thermistor.
Shows how much I know lol. The pin layout is still the same is it not? I'll have to grab the datasheets again and check...
As for the temperature sensor - I'm using a leaded NTC thermistor so I can place the actual sensor tip closer to the LEDs (or whatever parts I specifically want to keep an eye on). Granted I did not realise the 25 had an internal sensor - I chose it for the added flash so I can have more complicated code and features.
I'll post in DrJones' luxdrv thread and see if he can help me convert the luxdrv to run on the 25. He seems to be very busy at the moment though so I may be waiting a while :(
Recently, I have modified Tido’s codes to suit my driver with LM45 temperature sensor. Three modes, light level step down to a pre-set level when over-temperature.
