So here is the deal my plan. Lemme know what you think will work best. Tight space constraints and doing this on a budget.
I have a Ledil Seanna lens that has been sitting there for a year unused. I plan on using a defined XP-G2 in it.
I want to open up the end on a 50 cal fat boy ammo can and mount the 6.6” lens
I plan on water cooling everything with a cheap reservoir/pump
I plan on soldering the LED Noctigon to a copper plate and then soldering a water block to the copper plate. Then I’ll solder a heatsink and fan to the water block. I’ll have two water blocks with heatsinks and fans. One on the Noctigon and another in the back of the can just to help cool the water. I’ll cut holes in the can as air inlet and exit ports
I may possibly use these fans as they are cheap.
By actively cooling the LED with a lot of copper, water, and fans, I should be able to push it pretty hard. I really can’t think of another way to use this damn $60 lens so this is what I came up with. I’ll have to have 12v for the pump and fans and 3v for the LED so two power sources. Let me know what you think.
You could drive the 3V LED from a 12V source with with a buck driver.
If space is a problem, 4 x 26350.
[/quote]
True, but I don’t know of any buck drivers that allow you to push the LED at all it’ll handle. Most are set currents. Basically I need a buck FET driver
[/quote]
The seanna lens is for XP-E and XP-G size LED’s. I’d rather not hack on it to accept a different LED. Plus it’s meant for long distance, something 12v emitters aren’t known for
I did similar a while back, but nothing as good or technical as your doing I used a hid not leds, anyway, I used a nos 12v battery pack meant for a 11 inch Samsung netbook to power it, fitted in the limited space I had perfectly , charged the pack through the pins with a made up cable and using info from on here.
The cells on some small Samsung packs are the purple icr18650 30A
(4.35 volts) which was a nice bonus, pulled the 2 packs apart when I’d finished with the torch/project.
Anyway just a thought, but they do make a nice safe self contained power source
Or use 3S only setup. Both fans and pump probably should fine on it, even if a bit slow in the end.
Or just some adjustable voltage regulator and 4S setup. Or
ok, so I was having a brain fart. I didn’t realize the xhp 35 HI was the same size as the XP-G2. So, if I went XHP 35, how would I wire everything up and control everything. I could do 4S4P 5500mah 26650’s. That’d be a lot of weight but I need it to power the LED as high as it’ll go and 2 fans and a pump. What is the max current y’all are pushing through the XHP35’s?
I couldn’t tell you. I haven’t seen any real crash tests on this emitter. Four small dies at 2.5A each. I’m running one with a 2.5A driver, but tail reading is 2.8A.
If you are going through all this work anyway I would just get a spare emitter. Keep turning it up until the first one blows, then turn it down a little and replace it. And let us know what it could handle
