The one kreisler recommended above is worth a look. HKJ reviewed it here. I have a UT-61B and like it a lot.
Worth considering is what you want it for. If you're an electrician or perhaps a TV repair person, then you will be dealing with high voltage and therefore good input protection is a must. If it is for hobby use and you'll only be dealing with flashlights and thus low voltage electronics, then one of the Uni-T or similar products may work well for you.
Fasttech has a couple of the Uni-T meters.
