Ok, took some more beamshots today. It was daytime so there was a little extraneous light, but I don't think it affect the shots much. I took flood and throw on high and low. Same shot locations as above, 19.5 feet to the garage door.
Flood High:
Flood Low:
Zoom High (focused emitter image):
Zoomed Low (focused emitter image):
Camera remained on the same manual settings for each shot and very closely resembles what I see with my own eyes.
Informative and interesting. Reminds me of my Browning “Nitro”, which had all throw and little spill. It was pretty useful and efficient as a work light. The Nitro and phantom had obvious, out-the-front lens-related loss (no reflector); but the important “Visual Radius of Eye Detail Focus” or “Radius of Eye Detail” or “Red” was covered very brightly at low current and battery usage.
I just stumbled across this on the web. That 4AA headlamp is a clone of an LED Lenser H14. Seems the lens / optic system is much better on the Lenser. Sells for around $70 (Amazon).
I’m about to order this one OR the other one om ebay that runns on 2x18650, anyone who got some opinion 4aa vs 2x18650 and om the 18650version it comes
With à charger. Does it work the chargerplug on the 4aa version?
You can't use (4) 14500's unless you'd redo the battery pack to put the cells in parallel. Even then the AA's will be much safer and have darn near the same capacity if not more (assuming you use good quality AA NiMh cells).
The tilt works good. You don't lock it in place, it's just stoff enough to hold in place. I don't have the charger with mine so I can't comment on it. Personally I wouldn't trust the charger and would charge out of the headlight.
The (2) 18650 version is ok. Safe assuming the cells are parallel, but still not as safe as NiMh cells. You will get more runtime though.
i ahve the same light but using 18650 batteries, it can run with one or 2 batteries( longer run time)
i paid less than $19/free shipping ( now it seems they raised the price already) i like it so much, i decided to order 2 more.. and they're fast shipper too.. no drama :)
