Hi Dthrckt, they are perfectly secure no matter how much handling you do thanks to the soft rubber each type is made from. You won't have any problems with them falling out.
Most usb's put out 500 ma not enough for an iphone, i have burned out some cheap multi cigarette lighter adapters with 500 ma usb ports charging iphones.
I use this while play music in my man cave and plug the iphone into the cigarette lighter sockets not the usb port as it can not supply more then 500 ma, then plug the cigarette lighter adapter into my hobby charger's power supply.
I brought a XTAR - WP2 II Li-ion Battery Charger for my old man to charge is Torch batteries we tested it for charging Iphone 4's even though its usb out put is rated for 500 ma only, it fully drained a single trustfire flame 2400 mAh to charge the phone 75% and took a long time but did not burn out on the test.
So this torch really interest's me since it can charge our apple products correctly with decent speed and becuase there is 3 cell's in parrallel you could charge a couple of phones no problem and would be good for camping, but will need dust covers, i have added this to the wish list thanks for the great review.
I agree about the xtar wp2 II. I bought this as a li-ion travel charge and was planning on using with my ipod and htc phone. My ipod nano is a little older (4th gen?) and seems to charge this pretty easily. It also charges my htc phone, but very inefficient. Draining a panasonic 2900mah down to 3V (it seems to pretty much stop drawing current at 3V), it probably only charges it to 90%. I believe the battery in the htc phone is only ~1500mah; so its pretty inefficient.
I'm interested in tests to see how the USB output performs for this light. This might be a handy travel charger/flashlight.
Also what are the medium and low outputs for this light? having trouble finding that information.
Yes the usb on the xtar wp2 II stops at 3 volt and struggles to charge an iphone 4.
Since some are using the xtar wp2 II that has to plug into an outlet, then connecting that to cigarette lighter adapters, this Wagen Tech AC Adapter that I use is another fantastic item I'd be lost without. I purchased mine about 6 months ago from Walmart, which was the best price around. After using it for numerous projects, I don't know how I ever did without it.
My personal uses for it in the house are as follows:
Software updates for my Beltronics GX-65 radar detector.
Software updates for my GPS (Garmine Nuvi 255W)
Programming my Marine GPS (Raymarine A65)
Basically I use it to power any automotive item that plugs into a cigarette lighter that I need to use for extended periods of time.
http://www.walmart.com/ip/Wagan-5-Amp-AC-to-12v-DC-Power-Adapter/10928407
Update for Wagen Power Adapter - I also use it to rechage the battery in my Garmin Nuvi 255W prior to going on a trip so the cigarette lighter cord isn't necessary to use. I don't like wires strung over my dashboard in the car, so this is just another convenient use for it.
Thanks for digging those links up. That was a good find.
Just an IPAD2 charging update:
My wife was going to recharge her IPAD2 this morning, she said it was completely discharged. I removed the Redilast 3100's from the USB charger flashlight since I need them for the SRKing and didn't want to age 3 of the 4 cells. So I tossed in my 3 Redilast 2600's fully charged to 4.2v each. They were able to recharge the IPAD2 up to 84% before the battery protection circuit kicked in and stopped charging. To get the IPAD to 84% required about 2 hours 45 minutes. I'd have to assume had I left the 3100's in it, it may very well have fully charged the IPAD. I'm pretty impressed since the Redilast 2600's put out more power than the NewTrent portable charger we have.
Redilast 2600's are good batteries in my books
Thank you for the review.
Your all very welcome, thanks.
I decided to attempt recharging my Redilast 2600's in the flashlight today after they were depleted from recharging our Ipad2. I tossed them momentarily into the Pila to reactivate them after the protection was tripped on all 3 batteries, and then loaded them back into the flashlight.
Keeping a close eye on the flashlight while plugged into my desktop computer's USB port, after about 5 1/2 hours the blue LED illuminated on the flashlight signifying the charge current has been terminated and the batteries fully charged. I removed the batteries from the carrier to check the static voltage of each battery to find each one was exactly 4.19 volts.
This flashlight has impressed me yet again today.
Just a quick update. I've been playing around with this flashlight the last few nights. Just like my SkyRay KING, this light can run on 1 to 3, 18650 batteries thanks to the parallel carrier configuration. The flashlight can be used to recharge 1 to 3 batteries too.
Even better now, Rather than plug the USB charge cable into my computer, I've been using my Apple 1000mAh wall charger that came with the iPod Touch, and even the 2000mAh Apple USB charger worked perfectly as well.
Best part about this, my flashlights that require 2 or 3 or even 4 18650 batteries, I've been using this flashlight to balance charge all the cells. They always come off charging inside the light at 4.19v, whether one is being recharged or 3 of them, again thanks to the parallel battery configuration. For the first time in well over a year, my Genuine Trustfire Flames 2400mAh cells actually have a static voltage exactly the same.
Thanks all for now.
Thank you for the review. That is out standing. Now I just have to convince the wife that this is the flashlight SHE must have ;-)
It seems like a really good item - but after having a little while and using it how would you describe quality of the exterior? And handling in general. (I read the review but often I change my opinion of things after owning them and using them for some time. Maybe that is also the case here?? )
TY far any feedback :-)
Richie,
I measured mine 3.03A on Hi and These ICs are 7135 38L 380mA?
Hey LedSmoke, Well, my wife really likes it and mentioned how very bright it is. Although she doesn't like tail-switches, she did comment it's easy for her to press the switch and doesn't take a lot of pressure to turn on like some of my other lights.
As for handling, between the diameter and the excellent knurling, I honestly feel it's perfect. The diameter is similar to a "D" size flashlight. It's always felt very solid and of high quality. When I have extra money to spend, I'm going to purchase some Redilast 3100's for it yielding exceptional runtime and or charging capacity.
Hi Pok, that's a really nice sweet spot to run an XML. How did you manage to get such an exact reading?
I didn't look closely enough at the IC's, I'll take a look when I get home, but if you say they are 380mA, I'm sure you're correct. With that current, it's got to be putting OTF 800+ lumens after loses?
Thx for the great review Richie! This one has caught my eye since I have a camping trip coming up and given the single 2200 mAh 18650 in the Poldera PowerBank, it won't charge my iPad. That's great that you have tested this to work.
Cheers,
Tim
Hi Pok, I made that same mod you mentioned in your thread you started for this light regarding the battery carrier. I added some washers to one end to make inserting and removing the batteries easier. I used very small lock-washers pounded flat with a hammer so they sit completely flat prior to screwing them down. Works great just as it did doing the same thing to my DRY flashlight.
Also, I checked the IC's on mine labeled, 7135 and below that is 35B. I can't seem to find out what 35B represents. I did check my Roche F12 that has the same 7135 driver but without one 7135 IC and outputting about 2.5a, which is labeled 35C
Thanks for the review, Richie.
As a recovering flashaholic, I'm proud to say that I made it to the 5th of May before buying my first flashlight of the year.
But I definitely need this one...
I have the 3 mode, NW. Ordered on April 21.
Quality appears first rate, and it will be so convenient to be able to recharge without removing batteries. Put in three identical 18650 and these topped off quickly through the mini USB. Checked the charging output from the USB A port and this worked fine with my Nexus One phone.
My 7135s have a 35A label. Measured 2.8a, 0.8a, and 0.1 using a precision power supply.
As mentioned earlier here, there are three levels in the light pattern - the central is well defined for throw.
No complaints and pleased to employ more of my 18650 batteries.
Aloha and welcome to BLF jeober!
