Zebralight SC600MKII Pre-order is now live, we have also decided to make a general Zebralight coupon code, use ZebraStripes during checkout for a discount on all Zebralight lights! Please note our best estimate on when these lights will be in stock would be next week. Zebralight is notorious for postponed deliveries however…
The SC600MKII is Zebralight’s much awaited 18650 900 lumen upgrade. Please also note the color is usually different from Zebralight’s promotional material and is likely going to be lighter IMO.
Please note that nowadays(!) amazon.com marketplace dealers who fulfill thru amazon.com ship with DHL Global Mail, and not with USPS International. Any consignment shipped with DHL Global Mail (books, CDs, letters, packages, parcel, etc) are fully trackable thru trackitonline.ru or http://webtrack.dhlglobalmail.com/
DHL Global Mail is a product for US businesses by the US division of Germany-owned DHL. Get pricing from here:
hey guys i got my sc52 yesterday - what a phenomenal light! i dont know how i survived for so long without one haha
i have never seen such good deals on zebralights - i decided to jump on the sc52 deal after seeing a used one sell for MORE than illumination supply was offering for new - im glad i did!
might have to pick up a sc600 at some point well see
Absolutely love my SC52 as well, got mine from IS. It’s a floody little bugger, considering it’s about the size of an index finger!
Considering the SC600 MkII is only 20mm longer, and double the brightness (well, almost) it’s a no brainer for me. Hopefully IS can organise something for shipping. I’d buy one immediately if he waved the shipping costs
I’m glad to see you have the H51 listed now, since I consider it the most useful torch on the market, but its product details seem to be half pasted from the H502 and half from the H51.
Also very tempted by the SC600mkII, but I think ZL needs to modify their UI a bit to accommodate easier access to more levels on their brightest lights… would really like to see them change the UI to this:
High
H1 900Lm for the first 5 min and then step down to 500Lm
H2 500Lm
H3 270Lm
H4 strobe
Medium
M1 90Lm
M2 27Lm
Low
L1 9Lm
L2 2.7Lm
Firefly
F1 0.9Lm
F2 0.27Lm
F3 0.09Lm
Levels would rotate with a double click, like F3 -> F2 -> F1 -> F3, with no need to double-click a bunch of times first to enter a programming mode. Otherwise the UI would remain the same, with press+hold going up through primary levels from lowest to highest, and off->clicks going through primary modes from highest to lowest. The battery check would require five clicks instead of four.
The point of making this change is to make all levels more accessible without the need to space levels farther apart. ~3X increase per level seems about right, but it’s not as useful when one must click 14 to 18 times to switch between adjacent sublevels (which is how their current UI works). I hope nobody wants to switch between 9 and 27 lumens, or between 0.6 and 0.1lm, because it’s rather a pain.
OTOH, I’m fine with leaving the UI as-is for the high modes, because I don’t actually want the 500lm or strobe settings… Their current UI lets me pretend those don’t exist, and only use 900 and 270.
Looking over the numbers our margins on Zebralight are already not that high. The best I could do for international customers is to use the current coupon code, then I will manually refund shipping costs by $5. If you place an order from a valid international address, leave a comment during orders saying so. Sorry I couldn't do more :(
Thanks for the heads up, I looked over the description and modified it.
The reason I thought they wouldn’t fit is because I have protected Panny 3400’s, and they are long arse, button top cells.
I’m not surprised yours are 65mm if they are flat top unprotecteds.
This has me concerned about keeppower batteries too... they aren't quite as long as the protected panasonics, but still very long.
Hopefully the folks at zebralight took note of battery sizes and the final version will be able to cope. If not I guess I'll have to order a couple more 3400mAh flattops.
Well that's a bummer. I really really hope there is some more tolerance in this light... the sc52 handles the longer 14500 keeppower batteries just fine, a tad tight, but ok.
All of my protected batteries are either the panasonics, or keeppower 3400mAh... really would be a shame not to be able to use them. Maybe an extra GTID oring would work as a spacer.
You can’t use a spacer because of the tailcap design. The threads are anodized and the only part that makes electrical contact with the tailcap is the non anodized top of the body tube, makes contact with a copper ring inside the tail cap. It has to be screwed fully down or the light won’t work. You can disable the SC600MKII by unscrewing the tailcap only a 1/4 turn, so you can see how tight it has to be to make electrical contact.
I heard from an unofficial source that the recommended battery length for the SC600MKII is actually 67mm. 68mm is the absolute biggest battery you can fit allowing the tailcap to make proper electrical contact and without putting so much pressure to damage the electronics in the flashlight If you had the 2600’s you might just squeak it in, but I wouldn’t even attempt the 3100’s or 3400’s for fear of damaging the light
