Is there a way to check this before killing a light?
Unless you know the driver is rated for higher voltage than 4,3V. Do not use two li-ion batteries on it.
Here you can see what kind of amps (and voltage) all the common emitters can be run at.
Copper mounted emitters results are found here.
