Mine arrived today. Not bad, on first impression.
Plastic lens, for sure. Two red O-rings under the bezel.
coolwhite-bright-dim; warmwhite-bright-dim, blue-bright-dim; no mode memory — starts on bright coolwhite.
Actually useful difference between bright and dim on each color.
The flood for all of them is fine. And I can work with the spot, they’re a bit off axis of course, kind of like using an old 5mm LED light with its lens a bit off, but it goes where I point it. Quite small spot size, a bit smeared not perfectly rectilinear, again from being off axis, but as a working light, it does work fine for that.
3xAA carrier; 26650 cell is a little loose side to side but works fine
Can’t tell how the emitter is held in — press fit, maybe. No obvious way to get it out from the lens side without just prying at the edges. There’s an outside ring with notches all around it, and an inside ring, with the emitters held down under that.
Looks almost like it’d take one of those multi-armed pullers used on automobile axle parts to get it out.
Looking up the battery tube (head doesn’t unscrew from the battery tube) I can see a couple of cutouts in the edge of the driver board, so if I had a l-o-n-g needlenose plier it might be that unscrews from the back side (or pressed in, more likely).
Pictures in a bit, to the extent I can see anything.
Hm. If I thought it’d be easy to get the emitter out and back in, I’d find it very tempting to swap emitters to put in some more useful choices for my own purposes.
Not sure I want to tear it up trying though.
Nut light - emitters | Hank Roberts | Flickr emitters
Nut light - tailswitch | Hank Roberts | Flickr tailswitch
VERY noticeable blinking in the low brightness blue mode, both waving the light around and in the camera viewfinder.
