Both #'s are low, but certainly that 0.9a is way low - I got a consistent 2.1 - 2.2 amps on a good unprotected battery, others do as well. Make sure everything is tight with the driver area - screw down makes the contact to the driver I believe, has to be tight for electrical battery neg signal. There's no separate pill so not much going on there. Not sure if a poorly mounted LED would reduce amps, maybe - you could check the emitter mount. The plastic retainer on the emitter can be taken off by poking a hole in it near the outer edge and prying it off.
2 months old, fired about 60 rounds. Absolutely no issues, works fine, ‘kin bright [furthest ’lamped’ shot 217 yards]
Still smiling, and making my regular shoot partner jealous … He uses a 802 with a R2, its got a slightly better range, but doesnt appear to be as bright …. and the hotspot is a bit too restricted
Agree w this totally. I have the SF M8 which is clearly the inspiration for the Jacob. XML T6. The M8 blows this out of the water both on throw and flood. A bit surprised after all the buzz on this thread. Gotta play w it some more.
If he is testing the light with an average 18650, the 1.9a sounds about right. That what we use to get with my Eagletac protected 2500mah cells and even worse with our ultrafires & etc.
Now with our panasonic unprotected 3100’s, our Keeppower 3400 protected, and our AW’s, we always get 2.1+ from all of our A60’s.
Hi dave glad its working for you. I’m going to be building my iteration soon. Its your fault too I was happy not owning one till I built yours :bigsmile:
Very difficult to compare a SolarForce M8 to a Jacob (XML thrower to XR-E thrower) - think the M8 is 5 times the cost and it's an XML U2. With the Jacob you get 57 kcd for $12-$14 stock, if it's a standard one with an average battery, or up in the 70's or 80's kcd with minor mods, good battery. Definitely has no flood but that's not what you will get with a well focused XR-E. I'd guess from their website spec at 420 meters the M8 U2 is very good at about 45 kcd with 2 18650's.
Exactly the same is true for the one I got two days ago from Aurabuy (draws about 1A).
It is branded Jacob A60 and had a dent and a scrape in the front but the lens was clean. The heat sinking seems to be OK (no plastic spacer under the LED).
Apart from that it is exactly the same as the two I got from DX.
In order to assure that the reflector presses the LED star down and/or have the possibility to adjust the focus a little I file down 0.5 mm of the heads rear edge (below the logo) so that the LED assembly can screw a little further into the head/reflector.
I also did this on one of the DX ones that had the plastic spacer. Then I did not have to make a metal spacer to get proper focus.
My M8 is an original T6. I paid $48 delivered (that was a deal). Its a nice light, good quality, handsome design but never impressed me too much OTF, but it feels good in the hand w 1 or 2x batteries.
My other comparison is a common T6 C8 that I was never all that impressed w itself - although it out threw all of my P60’s. And so too the Jacob. So guess its time to borrow back my DMM from a friend who is figuring out some trailer wiring and see if that is the issue. I would take that ever so average C8 over the A60 (my example) anytime, except for looks.
The M8 sounds like a cool light even at the higher price but I do believe that the A60 from DX will out throw it and will considerably out throw the C8. Stock mine pulled about 1.9 at the t/c with Eagletac 2500mah cells and about 60k cd. Now after Tom E put in the 2.8A driver with an unprotected Panasonic it put out 82k. I just ordered an a/r lens for it from KD so am hoping for even a little more from this awesome little thrower. I was tempted to Buy one of those from Aurabuy but believe I will hold off because it seems like they are under driven a bit. I do like the way they are branded though with the Jacob A60 on it.
Being under driven does not worry me. I bought the light as basically as a functional host, there is no way I’m having strobe on a thrower. Or settling for 2a or so, I’ve seen what these lights can do with the right abuse.
I would advise anyone to get a 20mm contact board, 3 mode 2.8a nanjg and some thermal glue.
Build it up, to quote e1320 “pot the s* out of it” and enjoy, once these mods are done, you’ll have spent about $20 and it will significantly out throw most xm-l out of the box throwers. 8)
That’s exactly what I have been trying to tell the guys all along here about the Jacob A60 not beating some of my older XM-L throwers like the Crelant 7G5, Olight M3X or Sunwayman T40CS in throw. I sure can’t see it beating any of these nor can my camera.
I did get my Jacob A60 today from Aura Buy. It is brighter on a wall than the laswt one I got from Deal Xtreme.
Wow - there sounds like there's some crazy variations going on with the ones from AuraBuy, hoping it's all the stock driver, because like Gords, I buy them as a host. But also on the big A60 thread(s) early on from DX buys, there were variations too and it wound up being the paper under the star, no thermal grease, sloppy manufacturing issues. Also someone pointed out he's seen on some of the chinese lights, the thermal pad is not soldered from the emitter to the star - that could be the cause of bad performing lights as well.
For A60's, I've been using this driver from IO: nanjg-ak47c20, and add 4 7135's to bring it to 2.45A, usually set it for 2 modes of Hi/Lo where it always comes up on Hi. Also have been buffing off the anodizing on the pill top, sanding/polishing the pill top and bottom of star, and using a good grease - no epoxy necessary.
I just checked my amps from the Jacob A60 from Aura Buy using a Panasonic 18650 3400 unprotected battery and it was 1.486. The Jacob A60 from Deal Xtreme was 1.443 with that same exact battery.
