Sorry about that. The C8 was a mistake on my part, I mean the M8. I am very interested in these. I have read about the issues with cells fitting in the Convoy. Which of these lights do you prefer? Also, the Convoy is listed as about 1/2” shorter than the Jaxman, is this correct?
thijsco19, it’s easier than you might think. Apply the soldering iron to the mcpcb for a few seconds in the meatiest places around the board heating it up, then pry it with a small screwdriver or such. It will usually pop right up.
(I put the iron on the edge of the board between the optic holes, usually for around 15-20 seconds at each point)
Another method is (in both cases) remove the optic, desolder the leads, remove the driver. Then with a hot air station heat up the emitter shelf from underneath. Pry the mcpcb lightly and pop it loose.
Allright, so it’s just the MCPCB that is glued, but probably also the legs of the optic that stick through the MCPCB…
If you can’t remove the optics without damaging it, you can forget about heating it up to 150°C too…
Unless you have a spare Carclo in stock to replace the deformed one…
I have a JAXMAN E3 and a P60-Dropin with the 4000°K Nichia 219b and both have the loveliest tint, i’ve seen for a long time. It’s imho a lot better than the 5700°K option available also.
Recently received an E2 Nichia 219B 4000K from Jaxman. Wasn’t long before I swapped the driver with a Convoy New FW 7135*8. It really isn’t that Yellow as say a Cree in this color temp. Has some of the Peachy Nichia tint with some yellow. Also driven harder than stock it also reduces some of the yellow. No crazy colors outside the spot as some XP-G3 of similar specs.
I can’t complain and bought several more mounted 219B in 4000K from them.
The E2L is a great offering for the money.
Looks like the Warm White is already sold out.
Thank you Uli. I definitely like the Nichias as well but I was wondering about this warm yellow that Jaxman offers. Unfortunately, I think this is a Cree LED. Is yours the warm yellow factory tint from Jaxman Rick?
My JAXMANs are all Nichia 219b 4000°K, no Cree LED inside. The tints aren’t yellow, they are more like the “old” Nichia 219a, but not rosy, more “creamy” in tint. Can’t describe it any better, but the tint is very nice and if you don’t compare to a cool white side by side, whites are white to - at least - my eye.
No problem brother, I understand; too much to remember…… :person_facepalming: …
I don’t have the M8 yet, it has not arrived. I have ordered it.
I saw that the Convoy was listed as shorter…that is not correct.
Every listing of the Jaxman M8 I can find has it listed as… 130 x 34 x 24 mm
As far as the Convoy M1 is concerned, I have found three different measurements listed while looking at different listings.
So I measured one of my M1’s myself. It is…… 134 x 35 x 24 mm
So the Convoy appears to be 4mm longer overall.
When my M8 gets here I’ll PM you if it turns out to be different than listed.
Wow! I was just going off their AliExpress store where they state “Emitter Type: CREE XML2 LED, 3 kind of color temperature optional”. I would be please with Nichia LED’s in their lights if that is what they are currently using.
Thanks buddy! If I remember correctly, the Convoy listing I saw stated 115mm in length. If the Convoy is longer AND has the issues with cells fitting then my choice is much easier in favor of the Jaxman.
My pleasure pal. :+1:
Yep, that is exactly what it said… 115 mm. Now look at this listing for a Convoy M1 host . It says 137 mm. :person_facepalming:
I just now measured mine again. Dead on 134 mm.
