I ordered a brass pill, and a stock driver from Jaxman. I basically contacted Jaxman via email for the requested parts.
do you prefer the Z1 26650 running on 1 or two batteries?.
thanks.
The XHP 50 model will only operate on two 26650s. It does not have a boost driver using the stock driver. As for one/two battery preference, I prefer two for the size.
thanks, I have a modded Z1 from CRX at 3.5A 130,000+ Kcd running on 2 x 26650’s.
good enough for me.
would there been a difference if the light from 3.5A using 2 x 26650’s to 5.5A LED4P Driver using 1 x 26650?.
KCD?.
benefits or disadvantages?.
thanks.
Jaxman Z1 Help needed.
Hi I am trying to find out the sizes of the O ring on the Tail and Body Inside the Jaxman Z1. could be 019. seem thick on the tail.
I have some on the outside ( but not sure if they even supposed to be there ), but I am sure the ones on the inside would fit the outside.
anyone with a Z1 if you could measure please.
would it be possible to swap whatever LED thi light has for the sbt90.2? or the 90.2 too large fort he light itself? or just nope
Probably yes. If you would like to use mcpcb from intl-outdoor you would have to:
• reduce the mcpcb diameter to 29mm
• drill new holes in mcpcb
• sand the pill to make it flat
• drill and thread new holes in the pill
• make a special washer (the pressure ring must rest on something and it is better not to be led)
Hi!
Is there a way to get rid of the yellow fringe of the beam?
What options you could think of?
Thanks
DC Fix helps smooth things out.
Is this the regular frosted film for windows?
How resistant to heat could it be? The Z1 gets really hot!
Thanks
Think I've posted this somewhere else .. but this is the appropriate thread i think .
If you want a quicky pop on pop off diffuser for the Z1 /Cometa .
-Cut a round disc of diffuser film and drop it into the cover of a roll of teflon tape ..shove lights bezel in and you're done .
An 11 second mod that fits like it was made for it . perfectly buttery smooth flood at 180degrees instead of that round sharp cut off from light to darkness .
paint the cover black with spray paint or a permanent marker ..or go buy teflon tape with a red /green /blue/ yellow cover .
One of the simplest mods on the planet
Easy !
