Just received mine yesterday. Overall is pretty satisfactory. The anodization is flawless as with my other Jetbeams. The beam has a more pronounced hotspot compared to the UT01.
Tried to flip the clip the other way round, while it will mount, but it won’t light up. Guess it lost it’s contact with the space taken by the clip on the head side?
Wondering which way to lock out is better without slight drainage on the batts? Press and hold lock out or turn the head slightly to cut the contacts?
As KK pointed out, having a single e-switch is the issue here. When you do a single quick click, how does the light know if you want it to turn off or progress to the next mode? There is no way for the light to distinguish the possible intentions of the user here, unless it has some kind of sophisticated pressure sensing algorithm and hardware like some smart phones do, where a soft press means one thing, and a higher pressure press means another.
I have two lights currently with side e switch from different manufacturers the behave in this exact same manner. It is very intuitive to me that if I’m operating an e switch light, a long press turns it off.
Thanks for the info. So this again shows the limitation of a single e switch. Long press/press-hold is utilized here for mode switching instead of on or off. It’s a case of pick-your-poison.
Some people are going to be mad that they need to hold to change modes, just like some here don’t like to hold to turn off. To me, between the three choices of which operation to assign long press/press-hold, I would choose off. The reasoning here is that there is likely less urgency to need an instant response from a light since you’re turning it off, compared to someone who might be frantically trying to get usable light while turning it on or getting to the right mode.
I have a couple of Thrunite TN20’s. IIRC interface is:
Long press from Off: Firefly
Short press from Off: Memory (last mode on)
Short press from On: Turn off
Long press from On: Mode rotation
Double click from non-turbo (including off): Turbo
Double click from turbo: Strobe
-Regular short click to ON (last mode)
-Hold to Moon
-Double click to Turbo
From On:
-Hold to scroll Low/Med/High
-Double click to Turbo from anywhere
-Double click only from within Turbo for Strobe
-Regular short click to Off
So you have direct access to three brightness levels from off- the lowest, the highest, and one between those. There is no frantic searching problem. And you maintain the logical and intuitive function of single normal click to turn on and off. And there is little to no chance you would ever activate Strobe accidentally. To me, this is the best of all worlds. The light can function as a normal flashlight turning on and off with a simple click to suit the needs of 90% people, and to the mode changing junkies (what are you guys doing anyway?) you can access the lowest, highest and a middle mode directly from off without scrolling. And it does this without making one action similar to another, and without some timed hold for 0.6 seconds to do X but 0.9 seconds to do Y garbage.
With a little bit of thought a single switch is not a limiting factor. It’s only limited by thoughtless design.
I have both E10R and E01R on the way, so hopefully I will like the UI. I already have some Olights, including the S20, whose UI I like a lot. The press-and-hold from off to get moonlight is really useful, while still keeping the simple single press to get the memorized mode.
