My wife and I also regularly use strobe mode. There is a very effective dual-frequency strobe on the Q8 that we love. It is the second mode in the strobe cycle. Once you get into Strobe mode, half click one more time to get into it. You have to do the half click pretty soon (< 1 Second) after getting into Strobe mode.
No, the risks are just greater because in the usual devices the 18650’s are always packed in fixed packs surrounded by safety electronics that monitor the charge status, balance between batteries, and those battery packs will cut off when a worn-out battery is detected. In flashlights battery-monitoring occurs or not depending on which flashlight it is, but the monitoring is never as good as in the normal consumer devices. Still if you use quality batteries of main manufacturers you should be fine using them in flashlights.
I’m probably going to get dogpiled on for saying this, but I wouldn’t put that much importance to that.
All the cells are in parallel. Let’s assume just 2 cells in there, a high-drain 30Q and lower-drain panny-B. In parallel, the terminal voltages will be exactly equal, whether switched off or going full-tilt. You’re basically crowbarring the cells together in parallel, one end the tailcap, the other the big honkin’ brass circle.
So let’s say you’re draining full current when switched on. The 30Q will drop to a certain voltage, but so will the panny-B. Even though the panny-B will sag a lot more at the same current than the 30Q would, they’ll naturally balance. So if the 30Q drops to 3.90000V at 10A, the panny-B will also drop to 3.90000V but at only 2A. The internal resistance of each will determine how much each one sags at a given OCV (open-circuit voltage) and current draw (I²R drop). Period.
Look up what’s a “load line”. Just like the volts-vs-rpm curve for a motor, you can know exactly how fast the motor will spin with a certain applied voltage, if you know exactly what the load is over the range of rpm. Where the 2 lines cross will tell you. So it is, each cell will have its own load-line as well, and will let you know exactly how much each cell will drop for a given current. When you can define the current of the LED with applied voltage, you can exactly calculate how much current each cell will supply, and how much current for each, and the voltage at the terminals.
So while it may be extreme, you can use primo 30Qs and VTC6es, in parallel with ancient laptop-pulls.
Magnets are just a bad idea . they are dangerous / move around and dent your batteries because they are usually much smaller than the surface they sit upon .The forces of pressure created by screwing down a tailcap can be pretty massive .
A solder blob works much better .So damn easy I wondered why I ever waited .Never seen a light that wouldn’t run on a flat top cell with a solder blob …
Too easy !
A few years ago I had a moved-while-screwing-the-tube magnet short a Panasonic 18650PF inside a mechanical e-cig. In 1-2 seconds it heated up to to a point that I couldn’t keep touching it and I almost burned my hands while unscrewing the tube to open the circuit. What was going to happen next, I am not sure. Maybe just melt the e-cig, maybe vent through the vent holes of the e-cig and successfully launch it to outer space, maybe the vent holes wasn’t big enough and couldn’t prevent the tube from exploding. And these are my thoughts about only one “safe”, high quality, high-drain battery in an e-cig with vent holes. I can think of worse scenarios than that if using a flashlight with no vent holes, 2/4/8 18650s and, maybe, less “safe” cells.
So, yes, no magnets.
Yeah, might do that. I have a S2+ in the mail that I need a cell for anyway. I was going to use a protected cell in that one, but I’ll stop at the vape shop and see what they have if nothing shows up in today’s mail.
Not exactly desperate, wasn’t really even expecting to have it already, but I will have opportunities to use the Q8 this weekend and it would be a shame to leave it at home.
No,
please don’t do this.
If you run a Q8 on full power on a single Samsung 30Q it can heat up the spring and it will lose tension and sags.
Somebody in the Q8 thread had done this.
Edit:
It seems it was the Miller with two 30Q on full throttle.
Yes thats true. The lamps where prototyps. But I don’t know how much better the production springs are.
The principle is the same with one battery you have 4 times the current and a 30Q can deliver this, the spring gets hot and weakens the tension.
I wouldn’t risk it.
But you can use the Q8 and one cell if:
- don’t run it on MAX or
- you use a half empty high drain cell
when you have bypassed springs you can use MAX on a fresh 30Q
Having hard time finding decent button top batteries for Q8. Most places are out of stock.
Is Banggood or aliexpress reliable to get batteries? Any other US source with good batteries in stock? Leaning towards Samsung or Sony but open to suggestions.
