Just received my Opus BT-C3100 V2.0 from the GearBest group buy in 2 days flat. Some Initial Impressions...
Yes, generally I do not expect people to disassemble their chargers to use them.
There is also the point about the switch being undocumented, maybe it will be removed in next hardware cycle or maybe next hardware version will get an external switch.
Without knowing what is planned I did not see much idea in testing it.
I think you are right in the idea that this charger is, and probably will be, a work in progress.
If that switch is located close to the edge, I will consider using the Dremel and make a small cut out to access it. I am guessing it will be a small dip switch.
That’s why I am hoping someone tore into this thing.
As far as the heat thing, I like to prop up my I4 when running it hard and it seems to help quite a bit, hopefully this thing will respond as well and keep the temps down.
Thanks for all you do HKJ!
Keith
It is close to the edge, but not a dip switch and it is mounted the wrong way.
I stole this picture from Chloe (Top about the middle):
This looks doable. I can label the bottom of the case and just use a small jewelers screwdriver tip to move switch to proper position as needed.
Thanks for finding the Picture and Thanks Chloe for taking that and more pics of circuit board.
Disassembling
fonarevka.ru
hmmm…
seems that my charger loads a little to high / /reads a little to low ???
4 cells had 4.18 on display / 4.23 on DMM (+/- 0.02V) - settled 1-2 min
if DMM is right - would that be within tolerances for 4.2 Volt Cells?
+/- 0.05v is really all you can ask for with most chargers under $100
Do we know yet if it charges LifePO batteries?
Mine also come off high. After resting for 10 minutes they read 4.25V
