As much as I respect the skills of some of the knife users that spend an hour making an m4 or better blade into a knife that will last 1000 cuts on a manila rope, I am not that type of guy.
I simply want a knife that works as a knife for the duties I need it for. Some people need them to last longer, cut more, or cut through things that I never will, and more power to them.
Personally, 90% of the time I’ll use a knife to open boxes with that clear plastic tape that is hard to break by hand, or to cut through cardboard when the box opening is not convenient to my purpose.
Some experiences I’ve had:
1. Opinel #8 - when I used to smoke cigars outside regularly, I tested a couple knives shaving dead wood near my chair. I was surprised at how long this knife could go without needing sharpening (probably because of it’s thin blade stock). The Opinel #8 and 9 would probably be carried more by me if it was easier to open one handed. The knives take on a completely different level of comfort when you grind/sand the handle to your hand’s preferences… especially because my preffered grip is the hammer grip.
2. Since I sometimes need a knife for food on ceramic plates, a butter knife with sharpened serrations (off of the blade edge) can cut well, and the sharpened scallops never touch the plate and therefore don’t get dull as easily. 90% of what it cuts would still cut with a butter knife, but things like gristle or harder vegetables benefit immensely.
3. My first Spyderco was a Paramiltary 2. On the second week it fell out of my hand onto a tile floor and broke off the tip. I reground the tip and it’s fine enough. Although not common, I have dropped a knife or two in the day, especially when doing manual labor.
4. The few times I’ve had to cut through thick cardboard or other material giving resistance that requires more pressure than a thumb (therefore hammer grip required), I’ve really appreciated a fatter handle. This is why I don’t carry the PM2, BM 940 and 942, or any other high quality thin handled knife.
5. Over the past 5 years, the knife that I usually reach for is a LM Crater (the one with the tools since it has a thicker handle and I use the phillips often enough). The blade steel is mediocre, but the blade is thin enough and is easy enough to touch up that it gets the job done for small tasks when a more work/task specific knife isn’t around. I was rather happily surprised that the serrations cut though wires (like the ones that plug the fridge into the wall… unplugged of course) with little effort… I don’t like sharpening serrations though. The blade did show some slight signs of damage when cutting through some aluminum down spouts and related elbows when reconfiguring a down spout to run from the second floor to the first floor gutters, but it was easy enough to touch up after the job was done. It was a small job where I forgot my snips.
5 1/2. Although my LM Crater is my go-to, for casual carry one of my favorites is a Buck 112 w/ finger grooves.
6. I’ve cut a couple hundred feet of R13, R15, and R19 fiberglass insulation. My ZT 0909 with S35VN steel (that particular model was known to have been heat treated a little too soft) cut about 10 feet before becoming so dull I could run the blade accross my skin with no damage. My 89 cent boxcutter (extra blades included) cut about 100 feet with the original blade and was still usable (blade shape/tip was a factor). THe box cutter also made short work of a couple rooms of wall to wall carpeting for cutting into strips for the garbage collection. I wonder how a carpet cutting blade (like a hawks bill) would work on insulation.
7. I’m still figuring out how to sharpen my kitchen knives well… I should really invest in a good wet stone, but have made do with the ceramic tri bars from Spyderco and a few diamond coated sharpeners. I can get them sharp, but they don’t stay sharp very long. Maybe my cutting board is too hard (OXO Utility Cutting Board). My most used food prep knife is an 8” Vic Fibrox.
8. I got yelled at (at least the equivalent of yelling on a knife forum) when I suggested using a limited run knife for actual cutting. It’s great that some people are passionate knife collectors, but that’s not my thing.
