Be aware that some of those heat pipe units only work in one orientation (i.e. base down). Also, you are likely to drill into a heat pipe if you drill and tap into that surface. I would go with a fan cooled CPU heatsink. The one that I used in this can handle over 150 watts and barely gets warm. It is the same one that Scaru is using. The fan is quite the little screamer, though:
