I just installed the ld2 in a new light and it seems like the modes I’m getting are high-high-low. I opted for a 12amp resistor, has anybody else had this happen?
Edit: It seems I’m getting m-m-low, the high won’t come on.
Looking for some advice. I have this in the triple pilll from my blf ti from rey, which has a a screw in retaining ring.
Earlier it wouldn’t turn on when assembled. That seemed like because the emitter leads on the battery side of the ld-2 was shorting to the ring so I ground that w my dremel and then it seemed OK.
Now I noticed the opposite problem when I use a longer protected battery. When I screw it tight the light turns on high and won’t turn off.
Why would anyone power single xp-l with driver set to 12A max?
0,24A , 2.4A , and 12A are L-M-H currents for 12A setup,so no wonder that you have two "high" modes,visual difference between 2.4A and ~6A(that's probably the current on high with fresh cell for xp-l) is small.
This seems like you have short because of longer battery,do you have some kapton tape or even better round led gaskets/insulators for spring side? Which spring did you solder?
I tried covering the entire battery side of the driver (except of cours the spring) with kapton tape, but it still does the same thing. If I use the Eagletac protected battery, the light turns on in high mode (apparently) when I screw things together.
I’ll try, but I might not have said this. When I try the Eagletac battery, the light doesn’t come on when I START screwing on the body, but it comes on when I tighten the body at a certain point.
[EDIT: In other words, whatever is shorting is only shorting when I tighten the body.]
The other weird things is that if I then start UNscrewing the body, the light stays on almost until the point that I have the body completely apart.
If I put the light on high mode, it blinks after ~3 seconds, then drops to lower mode. Is this normal? And is it due to temperature protection (I don’t have the NTC sensor installed)?
Can this be disabled so that I can keep it on high longer?
Are you saying that is the battery protection? Is it checking for low voltage? Or current?
This is happening with several of my (different) batteries, including the Eagletac (which is protected) and several Efest batteries. Some of these haven’t been used in awhile so I’m charging them up now and will try them again.
