So when people stack the 7135 chips for more power, they’re basically changing the chip to a higher level of output as though a different chip were used? How is it that the chips can be added seemingly without discretion, in whatever number is wanted to step up output?
Wouldn’t it be nice if there were a plug in module for the blinkies labeled “pull” so they could easily be done away with without affecting the other performance of the board?
This really helps me understand the throughput, and why it’s better to have a driver than use direct drive. Thanks again.
You are paralleling current sinks so each chip will adjust its internal resistance so that it sinks its setpoint current - with these chips you can get integer multiples of 0.35A. For in between values you can shunt this parallel network of ICs with a resistor.
There is another issue and that is the ‘compliance’ of the current source.
What he said. Where ever you buy the driver should have info on star connection/mode selection. If they dont, buy elsewhere. The last thing you want to do is swap a driver and STILL be stuck with blinky modes unless you have to be.
Thanks pyro for the rev protection note, forgot that little tidbit
As for the mode selection, if you buy the two group version, the stars have no effect on functionality. Only the four group version uses the stars.
confused a bit. Dimbulb didn’t say even integers only so isn’t he correct? Since integers are simply whole numbers 1 x 7135, 2 x 7135, 3 x 7135, etc. these produce integer multiples of .350 A. Feel free to give me the face rub if this is not so.
Sorry, the main reason I thought it was so funny is because years ago I had a boss that was a retired supply seargeant, he’d get pissed and do a seriously wack face rub that required him to remove his glasses. “Dale, I’ve seen everything from a Jewish wedding to a Mongolian goat f*#k and I have never seen anyone do things the way you do!”
