But there is such a huge difference, 11-12mV compared to ~0.3mV
Yeah, I am not sure this is the case, just my best guess. I have seen pretty big differences before and the ratings are listed as max ratings. But that is a bit extreme I admit.
The new 17mm high-power boost driver will open up some interesting possibilities for triple lights. It will be possible to use high-Vf LEDs like the Cree XP-G2 and Osram Black Flat in a triple configuration with a high current through each LED.
Yep, I plan to swap out the driver in my EDC with this one for just that reason. I still have a hard time finding a better tint then my mixed tint EDC. Although the 90CRI XHP50.2 I have been playing with looks promising, if I could find it in 4500k it would be perfect.
Why is xpg2 so interesting when we have xpl hi, nichia, sst40, samsung, luxeon? What am i missing here?
Not sure on the XP-G2 in a triple, I have xp-G3’s in my EDC right now as they provided the best high CRI tints I have found so far.
I have high hopes for the XHP50.2 though, early tests say it should be able to give around 1500 more lumens OTF compared to my existing setup and have technically higher CRI (mine is around 85cri right now).
If I could just find a 4500k 90CRI xhp50.2 it would be perfect based on tests with a 4000k and 5000k 90CRI xhp50.2.
It has a higher luminance at the same current. Instead of 7A you can drive it with 4A for the same throw.
As LD-40 is discontinued, there is currently no buck driver for red leds running from a single li-ion cell. (In the hobbyist laser land, they have flexdrive for current upto 1A) It is really a shame since efficiency of red leds keeps improving and we still drive them with 7135s. I have plans for building XPEEPR (deep red, 51% wpe) triple using a Sofirn C8F and run it at 2-3A.
I have searched a lot on TI, Linear, Onsemi - the best chips are made only for CV type application (2.5V rail), LTC3561A and LTC3612 are very promising. To design a pcb from their app note is a huge challenge for me (could take a year), because I could not just copy the app note circuit, I also should use another fet and mcu to support momentary switch and modes!
EDIT: Maybe using an Ledengin lz-4 (4 deep red dies in series) in a Convoy L6 is a better way to go, but that’s too expensive.
I plan to make a buck driver for an EDC build for myself (after I finished the 17mm boost circuit). I could make a 17mm version as well. It would be 1S only though.
Do you plan to make a boost driver for XHP35? If so, will it boost from 1S, 2S or both?
Yes, and both :+1:
Very nice
. What max current do you expect?
roughly 6A with 6V config, up to 3A with 12V config
Waiting impatiently
Will it have the custom firmwares normally used here?
Initially Bistro HD, as to others - there’s hope that at least some will be ported.
3A @12V and 1-2s will be a nice option to have. I like the H2-C based XHP35 HI light I built, but I’d really like to push it past 1.5A.
Looking for Emisar D1 firmware, simple 3-4 modes, temperature controled
Really good thread about loneoceans’ new driver: [ GXB172 - 50W Single Cell 17mm Boost Driver! ]
This driver has many similarities compared to the driver I’m currently developing (with the help of some others).
