RapidLux
(RapidLux)
81
I would choose 500S as it has temperature sensors to prevent overheating and supports charging 21700 cells. These cells will become much more common than today. No doubt you will need a 21700 charger. Other chargers can be Miboxer C4-12 and BLF UC4 Also Liitokala Lii-402 will in not long time be upgraded to fit 21700s.
I would not recommend the BLF charger to non-experts as it will have too many options requiring some technical knowledge, but I intended to mention that the 500S accepts most 21700 cells, which will almost certainly be more and more relevant in the future. Thanks to RapidLux for pointing this out.
Unless something weird happens, 21700’s are likely to become the standard cell for medium to large lights and they won’t fit in the 500. I have a Sofirn 21700 and do fit it into my Lii-500, but it barely fits and cramming it in there tends to bend the battery sliders. Don’t try this at home
Rayoui
(Rayoui)
83
I have the 500S and Samsung 40T and 50E both fit with room to spare. I don’t think it would fit protected cells though. My Nitecore UMS2 can fit protected 21700 cells.
briankdk
(briankdk)
84
thank you all for the very nice answers - i allready have the 500, but 4 days ago when i needed to use it for the 9-10 time since i bought it 14 months ago, it almost cought fire (smoke started to come out of it), so i imediately disconected it from the powergrid……
so i have to order a new one, but judging from your guys answers, it should be the new 500s that i buy, instead of the 500
RapidLux
(RapidLux)
85
Are you guys happy with the new Lii-500S? Is it a good replacement for the old Lii-500 or would you go for another charger? Does it take protected 21700 batteries? When will there be a real review of this charger?
Rayoui
(Rayoui)
86
I picked up this charger a few months ago because there was a sale going on and it was cheap. I used it a couple times to successfully charge some 21700 and 18650 cells. When a cell completes charging the indicator for that bank turns green and the charger beeps. A couple of weeks ago I was using this charger to top up a 30Q and I felt like it was taking an unreasonable amount of time. I checked on the charger and the light was still red and the screen indicated that it was still charging, but the voltage reading was 4.20. I took the cell off the charger and measured it with a multimeter at 4.27v.
I thought it might have been a weird quirk but didn’t use the charger again for a couple of weeks because I didn’t really trust it. I decided to try it again today and put a Sanyo GA in the charger. I watched it closely and when it reached 4.20v it did not chime and the light remained red. I waited another 10 minutes and took the cell off the charger. When I measured it with a multimeter it was at 4.23v. I decided I didn’t want to keep a charger around that I can’t trust not to overcharge my cells if I don’t babysit it. I unplugged it and tossed it directly in the bin.
Jerommel
(Jerommel)
87
The 500S can’t do LiFePo anymore, can it?
Rayoui
(Rayoui)
88
No, the manual specifically states it is incompatible with LiFePO4. That was the first thing I checked.
Barkuti
(Barkuti)
89
Can't do LiFePO anymore? As far as I know the 500 can't do LiFePO either, at least not without a mod. ;-)
Jerommel
(Jerommel)
90
Oh, i didn’t even know that…
Are you sure?
Yes. The Lii-500 amd Lii-500S support only li-ion (4.2V) and NiMH (1.48V).
Jerommel
(Jerommel)
92
Well, so be it then.
I have 4 of those big 32650 / 32700 LiFePo cells coming my way, and i was hoping to be able to test the capacity with my lii-500.
I’ll have to think of another way to do that then.
Thanks for the report. I don’t know what’s wrong with your charger, but I agree that it’s utterly useless if it won’t shut off properly, as even $0.21 TP4056 modules will properly terminate.
Forever
(Forever)
94
Sounds like a bad unit, I’m not seeing this behavior with mine.
Barkuti
(Barkuti)
95
Get a proper testing device, there's an affordable electronic load / battery tester which can be had for little money:
Features PC software which plots discharge graphs. I have one right here still untested, waiting for my holder.
More information here: ZKE Tech EBD-M05 help
Rayoui
(Rayoui)
96
Indeed, my unit was defective. Strange that it worked fine a couple of times before it started acting up.
Failing to terminate charging is a pretty dangerous failure mode. It’s certainly something to watch out for if you use this charger.
Ah, I remember coming across that before and thinking that someone should let the store know that their name has a rather unfortunate connotation in the U.S. I didn’t
LTC
(LTC)
98
Oh no… That’s sh*tty to hear that. Will be receiving mine in a day or 2. :person_facepalming:
Barkuti
(Barkuti)
99
This charger lacks any trustful review worth reading yet. Additionally, two out of the latest three LiitoKala chargers reviewed by HKJ (Lii-S2 and Lii-S1) have been found using nonsensical, harmful trickle charge on lithium ion cells. Now, without being explicitly judgmental with LiitoKala here, just tell me what you think, please. I'll judge
from there on, just don't want to binge. O:)
Vendeur
(Vendeur)
100
Guys… I think some workers and their bosses in LiitoKala are really braindeads…
http://www.liitokala.com.cn/productView.asp?id=484
and look at this picture…:
Are they really puting a microSD card into USB slot…
