Wow these things are complicated, whatever happened to just turning a light on and off again lol.
So if I’m understanding this correctly, whilst I might set my flashlight to 2000 lumens (hypothetically) it might only stay there for several mins and then drop down to stop it from overheating? If so is there something in the specs that tells me what the max setting is that it will run at without dropping down (at least for an hour or two)?
P.S. The Astrolux EA01s I’ve ordered is the XHP 50.2 version, I’ve no idea how efficient these are.
Thanks, interesting that if you want any kind of decent runtime it has to be below 1000 lumens. I’ve no idea whether that will be bright enough as my current light ‘claims’ to be 2500 lumens but the fact it runs off 3 x AAA alkaline batteries, and my friend’s Exposure Diablo that claims to be 1800 lumens is much brighter, clearly my current light is not 2500 lumens.
The link in the original post isn’t working and I was wondering what the best way is to ‘store’ batteries when the flashlight is not being used for an extended period of time? For non-protected Li-ion batteries is it best to remove from the light and store in a plastic case, or is it best to leave in the light so that it benefits from the low voltage protection supplied by the flashlight (Anduril). Likewise for a protected battery, I assume for a protected battery its own LVP would protect it regardless?
You may know this already but beam characteristics can make a big difference in the perceived brightness of a flashlight. At the same distances a floody beam has the lumens spread over a wider area. A lower lumen narrower beam can have higher lux and can appear much brighter because the lumens are concentrated in a smaller area.
That can make it hard to judge the lumen output of a light.
Thanks, yeah I appreciate that. After trial and error I’m finding roughly 800-1000 lumens on a flood beam works for us. I’m basing this on my P20ix being 850 lumen in high.
