The concern is that the fluorine compounds produced in the flame of a li-ion fire are inhalation and skin hazards.
Interestingly, a while back, some tests done in an argon atmosphere (no external oxygen available) showed no HF produced.
This confused some people; no HF was produced because there was no combustion, no flame occurred, just venting, in the absence of any external oxygen at all.
If the magnet slips to the side and contacts the battery tube while staying in contact with the battery, you have a short circuit of the full capacity of one or more cells.
If the magnet is secured ā fastened so it canāt slip sideways ā as glued in the middle of a disk or ring of nonconductive material, thatās avoidable.
it also depends on the INSIDE of the tube
my L6 and S70 have an anodized inside of the tube, so even if the magnet slides to the side there is no short (so I do not have any securing measures taken and use the fact that whey are loose in swapping the cells top/bottom at every charging, when removing the cells I plac the magnet from the bottom to the top and then in the charger so when inserting them I have onl ye swapping way to put them in.
Thought this thread is a worthy spot to put this article in
Quality reporting I know as details are a bit lacking - itās unclear the brand of headphone or cells usedā¦however it may serve as a reminder to people to be careful even with battery powered headphones
I actually have that same question about airplanes. Iām going to Florida April 9th and I have a rather large ANKER power bank which looks like it uses multiple 18650 batteries. Iām wondering/hoping I can take it on the airplaneā¦
Iād use it just to charge my tablet and my other familys phones or whatever they have
all fire-related problems that happen on airplanes will show up in the news, and the sources discussed.
Thatās because aircraft fires are taken quite seriously. LMGTFY
Problems elsewhere, well, if someone happens to put it on YouTube weāll know about it, otherwise maybe not.
For example, a while back, there were a lot of reports of vehicle fires in China attributed to li-ion batteries.
Then China cracked down on handling them and the stories disappeared from the news.
Thanks. I have the ANKER Powercore+ 26800 charger. Iām not sure how many Wh that is. Amazon answers said it can be brought on an airplane but I just wanted to double check
Thanks, I will print that out tomorrow when the stepdad isnāt home. Florida is a surprise to him. He thinks itās just 4 people going, so Iāll do it while he is at work
