Looking for extreme flood from P60 sized light
The SolarForce lens/XM-L2 in a P60 is probably the easiest/most cost effective solution.
If you’re so inclined you could build a triple XP-G2 and experiment with all the Carlco lenses, this is the first one I made. I’ve made 6 more since then and refined the process.
Or you could do something like this if you wanted an XM-L based TIR light. Again, it allows you to swap optics as easy as removing the head, pill does not need to come out.
