Yeah that do sounds like a good idea, but they are expensive though.
What is the termination current on the iCharger? Because as HKJ’s testing showed, if it is to high, the voltage will just drop a lot as soon as it has stopped charging.
Ok thanks, that is not bad. So if i would charge at 500mA it would terminate at 50mA, but i would like it to be 5% even if it would take much longer to charge because of stabler & higher resting voltage, too bad you can’t chose how much you want the termination current to be.
Very few mah’s (and very slowly) are added even during the last 20% of the cycle, I doubt asking for the 5% is practical for all intents and purposes, as those few mahs will be wiped out in just one click of a ‘turbo’ mode.
But then nothing about hotrodding lights and building a light with as low resistance in the circuit as possible is “practical”, i do it because it is fun to push things to the max & it gets me very very bright flashlights
And that means i have to try to optimize every part of the circuit, including the battery.
Even if the top output only lasts a few second, i still want the max that it can be & the max that i can make it do
The 4.35v chemistry has potential, but i think all batteries so far that has been released with 4.35v has been high capacity batteries, and not high drain ones, so they volt sag like crazy the first half of the discharge curve, just when you don’t want them to.
And the result is less amp at start.
For lower amp like 3 & below the are very good options, but not for max amp unfortunately.
It’s probably too late for that. You have almost 3 pages of discussion with people now nitpicking the details of charging specifications at a level to make a sensible person crazy.
If you WANT/NEED/REQUIRE 4.2v you WILL HAVE TO OVER CHARGE IT (a little), if your diagnostic tools are accurate.
You will NOT get a decent charger to do that at a price you are willing to pay for……unless….it is slightly defective.
IMO you should be quite happy with anything above 4.15v, which is completely IN SPEC, and normal.
You probably ought to pick a price range and detail the amount of ‘screwing around’ with it you are willing to do> as in hobby charger vs. plug and charge.
I think it’s hard to beat the Opus for overall use at an acceptable price.
I don’t mind the preamble, some of it is quite informative, it does not have to be 4.2V, 4.19V or whatever is fully charged is fine, i just want to finish with a fully charging charger (at the best price)
