When I ordered from Hobby King I loaded up on as many AA's and AAA's as I could order and stay with the cheapest shipping option. I got 4 AA's and 8 AAA's (AAA's were my priority). Total with shipping was still less than I could get Eneloops with free shipping.
Thanks Werner for searching!!
Didn’t know they were available overseas yet, that still makes the shop mentioned earlier the cheapest for the PRO version
800mAH white top Duracells that are made in Japan are actually rebadged Eneloops. If you want Eneloops, getting the Duracell badged Eneloops might be the way to go since they are typically easier to get. You can get them at most grocery stores, and they are often on sale.
Energizer AAA batteries are NOT rebadged Eneloops. They are made in China and have a smaller, 700mAH capacity. I have some, and they seem OKAY. But I certainly haven’t tried them for long. So I’m not sure about reliability.
Most people will tell you to get LSD batteries ONLY. But if you are looking for NiMH AAA batteries, it might be a good idea to get some HSD batteries in addition to LSD batteries. AAA batteries inherently have a low capacity. And if you have a AAA light that draws a fairly hefty current, runtime will be rather short with LSD batteries. Sometimes, that extra capacity that you can get from a HSD battery can mean the difference between being left in the dark vs finishing a job or a walk. The 1000mAH Japanese made Duracells seem to be pretty good. And the 1100mAH Ansmann AAA batteries actually seem to live up to their rated capacity! Of course, HSD batteries are really only good for situations where you will charge them immediately before use and you use the light for a long period of time right then. But this situation actually pops up more than you might think!
Getting an additional set of LSD batteries might be a possibility, too. But if the light uses a battery holder rather than simply having the batteries in a tube, changing the batteries can be a pain in the butt out in the field.
Uniross are excellent, I have nearly 100 AA (NIMH) a lot are Uniross, std NIMH, Hybrios also, amongst many other makes.
The Hybrios are defo the ones to go for, these can be left unused after charging and still have most of the charge left even after 6 months, I probably have 25-30 of those, performance seems to be better as well, despite the sometimes low rating.
As you can get nearly twice the batteries with u/ross than sanyo it’s a much better bet imo, allowing you to have a spare set, you will get more capacity per £ this way.
I also have Energizer/Duracell to name a few others, it’s a mad dash this time of year with xmas lights going 24/7 and chargers going 24/7!!.
The only issue I’ve found is sometimes the batts are a little fat due to covering(?) and area serious squeeze in some applications, I’ve only ever found 1 thing that didn’t like NIMH as opposed to throwaways.
I use mostly an intelligent charger that everyone swears by a LA CROSS, I bought the badge engineered one by TECHNO LINE, made by LA CROSS, it’s good but don’t thump the buttons like I did as they are a bit fragile in this dept, they also will NOT charge if the cells drop below 0.8V, but I solve this easy with the std Uniross charger, putting the low ones in this for 10 secs after which the LA CROSS is ok with them, charging up to 1500mah each(when just 2 are done at once).
Even when the charger tells me they are dud, they rarely are, and have gone on for many years, some are getting on for 10 years old now.
Don’t buy a s/h LA CROSS as they went through a period of catching fire!!
