About the math question. People are on the same page. That is a good thing right? I think so. :)
[quote=DBCstm]
Do you know, for instance, that rdrfronty himself built my lightbox, Tom E's lightbox as well as RMM's lightbox? All of ours are FROM rdrfronty.
[/quote]
I had a feeling about that, but I was not 100% sure. And based on your guys numbers its not that hard to notice. The issue is that you guys are not on the same page as many others. You guys are generally higher or much higher when it comes to lumen. Who else have as high lumen numbers as you guys? Who have higher numbers?
Who gets higher lux readings?
The only way for others to get those high numbers are either to try and adjust their calibration accordingly, or get the same lightbox/tube thingy you guys are using. As far as I know, its just form of tube with bends or something, not even a round sphere, so most would never agree to use such a device even if they could agree on the calibration.
When is the last time you bought a light from a well respected premium manufacturer and measured similar numbers or lower that was stated? How often have you measured lower compared to how often you measure higher? I have a good feeling you are used to be measuring higher.
I know your K50 numbers kcd numbers are more than 50% higher than Supbeams claimed number. I know your K50 lumen numbers are about 4% higher. I know your TK61 lumen number is about 20% higher compared to Fenix. I dont know what your TK61 kcd number is, but I bet it was higher compared to Fenix. Its not ideal for everyone to try and get a calibration as high as you guys because then they would purposely have to increase their numbers beyond what many manufacturers do. Manufacturers that many use as reference. And the purpose for non modders and reviewers are generally to be close to manufacturers numbers. Which supposedly have expensive calibrated equipment following the same standards.
One guy, rdrfronty, built your lumen boxes/tube thingys (and did the calibration?). Your boxes generally produce higher numbers. What is the point of only having comparable numbers with each others high numbers, when you could be having numbers that are comparable with so many others while having comparable numbers with each other?
Many others have individually done calibration work, and been able to match each other fairly well. You guys are typically higher. So it would make more sense for rdrfrontys box to match those other guys right? I mean, wouldn't that make it easier for everyone to compare numbers from different people?
