Lumens and "luminous efficacy" - tech question....
Luxmeters have a filter on their sensor designed to recreate the sensitivity of the human eye to different wavelengths.
So 500 lux of blue light and 500 lux of red light would appear as the same brightness to your eye.
Some cheaper luxmeters have worse filters and will give incorrect readings depending on how much of a certain wavelength there is.
For example, for this UT383 luxmeter here you can see that the blue wavelength gives a much higher reading than the high end calibrated luxmeter.
