Venom
(Venom)
December 13, 2022, 9:39pm
21
kokosnh:
It’s like I said earlier, the battery doesn’t have PD support, and it doesn’t have the two resistors to tell other devices, that it wants power. https://microchipdeveloper.com/usb:tc-pins Buying a PD USB C to C cable, won’t change that… It will not work. Just buy normal USB A to USB C cable, and that’s it. Ps. And the recommended max charging current of 14500 is usually rather small. usually 0.25-0.5 A (and the 0.5A is usually for the high current ones)
I just bought the USB C cable out of curiosity, if it will charge the 14500. I’m planning on using it for my phone. The Anker is thicler, better made than the factory phone cable.
I have a USB A to USB C cable. I bought for charging in the SUV. Charging the 14500 with this cable is no problem.
I tried charging the 14500 with my Vapecell S4 Plus charger. The charger selected ,250 A.
Venom
(Venom)
December 13, 2022, 9:44pm
22
I was just experimenting. Now I know I can’t charge with USB C to USB C cable. Maybe a cheap cable may work.
I’m going to continue using my USB A to USB C cable, or the Vapecell charger.
Is this a 14500 with built-in charger?
If so, it should be smart enough (or at least not stoopit enough) to charge at a manageable rate and not push it Just Because.
Venom
(Venom)
December 14, 2022, 11:55am
24
Lightbringer:
Yes, It’s the Lumintop 14500.
I tried using the Xtar USB Tester with the USB A to USB C cable.
The reading I received was 5,04 V and .42 Amp.
