Nice video review. I haven’t purchased one yet, but now I think I just might. I have no idea it was so tiny. I was hoping you had a thrunite catapult v6 to compare it with. That would be a awesome matchup.
How does the throw and such compare with a Thrunite TN4A? I know the TN4A is bigger/heavier, but I have it and wondering if the GT mini significantly out performs.
well looking the specs for the throw from thrunite it says Max beam distance: 326m. so the gt mini compared throws on paper twice as long it has a rated throw of 750m if that says anything ?
Thx for the feedback. I was able to look at the specs a bit and indeed the gt mini claims more throw and candela than my TN4A. Wish I could do a side by side comparison without purchasing . . . .
I know 2x lumens is not that noticeable, is 2x the throw at a couple hundred yards? I doubt I could see much at 750 yards
here is a pic i took a few days ago, the building i pointed at is almost 400m away, i can clearly see that it reached even tho it shows bad on my cellphone, but yea 750 u will barely see the beam reach i asume… but either way the gt mini is a killer thrower at this size for sure…
In that case the difference is not going to be huge. It’s hard to find specs for it but I did find some for a neutral white version with the xpl hi. Peak Beam Intensity: 52,340cd.
Max beam distance: 457m. It’s got a 46mm head compared to the GT Mini’s 50mm.
So the Mini still beats it. Plus the mini has a few more hundred lumens. I measured around 1200, but others have measured around 1400. My guess is that it’s not going to be as big a difference as with my C8, but still pretty noticeable.
Thanks for the clarification about the cells, that was a reason imo for looking elsewhere. Not a huge deal, but I prefer flat top cells in general, and think double springs are a plus also.
Ok, probably posted the v1.3 BETA for him to use on Nov 16th, then on Jan 28th posted a v1.3 with the "new" S42 support, but nothing seemed to come out of that, least not so far.
