Interested
I got my GT Micro a few days ago.
I’m absolutely certain I’d buy at least two Nanos for wife and I, and maybe two more for in-car backups.
Definitely want ramping brightness, wouldn’t need a huge head, not as much need for 20+ meter brightness given the 10440 cell wH limitations.
Nano nano? Are these still a thing?
i doubt it by now, last i heard they had issues doing the driver for this light or something… seems they busy with more fw3x models now…
More FW variations is much easier money. But the GT nano will be more unique.
the driver was not shrinkeable to 10mm without downsides to my knowledge
buu thats a shame… is not possible using a different driver or so ? or what if using a normal convoy driver then? no ramping but atleast the light would be possible make…
the problem was that Narsil and e-switch was too much
maybe a easier UI will do the trick
I wonder why is it so hard? Did they try to make it a boost driver?
I have a few 10mm FET drivers from Mtn, 10mm is really small, he used really small components to make it fit and there is no way that a normal size 7135 can be added to make it FET+7135, I’m not surprised that it is a puzzle to make this driver.
A good solution IMO will be to omit the 7135 and make it a basic FET driver. The 7135 on theGT-mini and Micro drivers is to make the low modes more efficient because then you do not need PWM-ing the inefficient direct drive current. But the direct drive current in 10440 flashlights is not extremely high anyway so efficiency is not bad to begin with. So there is no need for a 7135 in this battery size and I’m sure that without it a fitting driver can be made by Lumintop. Hint!
Actually there are a couple of 10 mm FET+1 drivers available:
I’d consider this build to be very advanced. It will certainly require reflow soldering, maybe require touchup, and almost certainly require filing of components. Fortunately the PCBs cost very little - order one to cry over if you would like. I do not think that this design can be done in a significantly better way. B+ strap required. You’ll have a diode and C1 on the bottom of the board, so the strap will go diagonally between them. 0.5mm of exposed copper on the GND rings IIRC. The 7135 is…
The NYMPH is Darkside’s first product offering… [redacted] It’s a compact 10440 twisty with a Fet+1 driver, a Nichia 4k 9050 219C LED, and an integrated grade 5 titanium pocket clip. The light features what I am calling a “sinusoidal knurl” pattern: [image] [image] [image] [image] [image] [image] The 10mm driver is a single sided ATtiny13a based fet+1 called the “DS-10DD+1” and is basically an evolution of the MTN-10DD by RMM. I’ve ditched the OTC, using mem decay for offtime instead, ad…
The first one is certainly not something that I would recommend for production. The latter uses a 3x3 mm MCU; there is no Andruil-capable MCU of this size yet (though maybe one day someone will port it to Attiny1616…).
So neither is a direct hit.
FET-only is much easier though and that’s what I would expect from this driver.
You mentioned MTN-10DD. I studied the design lately and I really like it. I intend to build one this year. It is not a direct hit either - because it also uses a 3x3 mm MCU.
But it uses 3.3x3.3 mm MOSFET as well. Shrinking the FET to 2x2 mm should allow 4x4 mm MCU. It would increase resistance but it would still be perfectly adequate for 10440.
So who is going to tell Lumintop?
I think we should ask someone who knows more than me to confirm. I’m far too noobish to be sure of my assessment. If they confirm, I guess Martin could talk with Lumintop….
Btw, the nano should come with a White Flat or Boost HM by default. My GT-Micro with Boost HM is the most amazing thrower in my collection, the size/throw ratio is ridiculous and so much fun. I think the Nano should have that same fun-factor.
Couldn’t 2 boards be piggybacked?
Maybe with some soft potting in the void, witch ever side runs the heat goes on top.
Would make the body slightly longer but still be small as heck.
Just a thought form the peanut gallery.
Technically it could be possible with small enough components I suppose. I know in the past I had trouble getting smaller then 12-14mm but that was with a larger mcu and FET.
A dual sided pcb with a separate battery contact PCB is the simplest option though.
a pic i took Oct 2019 when i was in the factory ;)
and yes - i am already pulling some strings
Great to hear!!!
Drop the driver! Make it on/off direct drive! ![]()
